  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
is there differnt warning points for different ruckus amounts?? Otherwise it only takes two warnings to get a ban..bit harsh
That would be Pending how long the banning is. On Ns.com its like 7 days for your 1st time, a month your 2nd time, and perm ban your 3rd time.
A ban for 48 hours the first time, 3 months the second time and on the third time they sell your account on ebay
Meh, 52% of all speed camera revenue is going into admistration. Fark me. Thats a lot of my hard earned money going to pay secretaries to type my name into the hoon database.
Hi I'm n00b here. I'm looking for a forum where no one even gets together let alone cruises where everyone is opinionated as all hell on th eintraw3b but won't back it up in real life and where people whine like little girls for no reason. am I in the right place?
Oh and I'm 18, 6 foot, stick thin, perfect skin and single. Does anyone want to talk to me?
I ate some tim tams, and sat in front of the TV for most of the night. I think I'm about half way through a bout of apathy because I don't feel particularly depressed. The house is a mess, nothing is done, my desk is covered in work I CBF'd doing. So basically it's a normal Friday. At least I got enough sleep.
Hope everyone who went out last night had fun. Yes you know who you are.
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
