  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
whats this I hear about a front grill?.....
Well I swapped my silver kick boards for baue's old front grille, its a wired looking one I hadnt seen before but it is painted silver so I have to sand it back, problem is that is has a shitty silver paint job over a even crappier white paint job so because I am lazy I have not sanded it back to then give it the ricy green treatment ;)
Should look good, if I ever get off my ass and sand the bastard! :D
It does not look like a SII grille, but then again I dont know shit, so it might be.
But the actuall grille metal part was crap so I removed it and so it is going to look like a cross between a SII and a GTR front grille, which again will be another unique part on the grean beast :D
I've got a disc sander if you want to borrow it cy.
yatala pies is open until...........half past eight. *silence* hahahahahahahahaha. Sucked in.
I dont really like the look of the louvers so might sand it back soon means I have to get sandpaper means I gotta actually sand it back hmmmmmmm too much effort to even think about, meh, I'll just leave it until I feel energetic one day :D
