  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Yeah but our users have plans and layouts and all sorts of other crap on their desks, the last thing they need is cables crowding up the place, cordless is great and the logitech are awesome, but of course magaement saw the microcrap ones were $10 each cheaper, save $100 and pay me a frig load more for trying to get them to be less powerful, go to the point of putting deadened batteries so that one user does not accidentally move the mouse on his next door neighbours computer! :D
where is your office ska? me pictures myself having a little fun out the front with an orphan desktop keyboard and mouse :D
it would be like a phantom interference on your pc and it was possessed by a spirit or something. Actually that could be kinda freaky!
chaos: yeah, there are viruses out that almost do similar. Install a trojan on your machine, then later they can get in via IRC and control all their little army of "slave" PC's to do their bidding. Kind of insidious actually.
Or the old fashioned "back orifice"
Byron? just chill out and spark up a J... :D
Im so over my current job, its good in so many ways, but there comes a time when you have to think about the big picture.... :rofl:
wana go bigger matty!! ive done my homework, damn coldwell are big! ask for a job in the states with em?
I could go to the states, but i have never wanted to live there.
Sure they are big, but it doesnt mean they will work here and now.... maybe in 12-18 months, but i have things to do NOW :D
Its been a shit day
/end rant..
Guest
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • I guess one thing that might be wrong is the manifold pressure.  It is a constant -5.9 and never moves even under 100% throttle and load.  I would expect it to atleast go to 0 correct?  It's doing this with the OEM MAP as well as the ECU vacuum sensor. When trying to tune the base map under load the crosshairs only climb vertically with RPM, but always in the -5.9 column.
    • AHHHH gotchaa, I'll do that once I am home again. I tried doing the harness with the multimeter but it seems the car needed a jump, there was no power when it was in the "ON" position. Not sure if I should use car battery jump starter or if its because the stuff that has been disconnect the car just does send power.
