ford explorer! or for a van an honda odessey! the new 1's! there is a guy getting round here in a slammed explorer! its tight! yeah and u are rite about that forry, it has got too mouch gold, but i wouldnt have done the wimdows in mirror it would make a world of difference to break it up. also those rims are dished a litlle. they were the 1's i told my mate to buy, bcoz they would look good against a black car. im not a huge fan of bling rims either, but if i had to buy sum they would be the 1's big chrome area with a dish. dont like all the fancy looking ones like snow flakes and shit theyre gay as! anyway there cool car when done up rite. there is a few of them getting into the 13's now, not a bad effort.
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
i saw some oldies trying to park a newish Ford 250/350/1111150 (because larger is better) in a tiny space recently at the shopping center. The silly byarch had to get out and supervise her elderly husband how he should get into the spot.
Now if that didn't raise a "why the **** did we buy this car again?" I don't know know what would! :D
Guest
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
