The run down to Geelong is going to be a slow smooth one to avoid the
fixed camera's that are down there now.
ash
The fixed camera's along the highway are not in use yet. I drive along there twice a week at 100kph+ (very early in the morning, hardly any cars at all) and have never received a speeding fine.
  • Replies 150
is the s/e point at that megamart? or are we gonna have one near glenny like last year, then meet up with everyone at megamart?
I thought about this BUT a pre-meet point means getting there at 8:00am for an 8:30 departure to get to the second meet point at 9:00. It just makes it a long long day - Id rather have the extra half an hours sleep! ;)
But if people want to do it then alls good - just don't be late! :flamed:
I have one point left on my licence til July and I am suposed to be infront on the way up so I can tell you right now Im doing 100!
Hi all.. I've never been on one of these things, so can I come??? I hope I 'm eligible, I own a R33 - this may get me kicked out before I'm even in but its a sedan. I'm from Northern Suburbs Melbourne and the Western Meeting point is the closest so can someone also from Western Meeting please talk to me...
KSV: More than welcome buddy! Just think of your car as being more unique, something hard to find when speaking about R33's :D. I too am a westy, and drive a R33 coupe (when the clutch is not slipping :) ).
On previous cruises we came back home by about 4-5pm. It's a long FUN day with heaps of km, about 450km round trip (if not more).
To all: Please PM me if there is a "shot-gun" seat available, closer to the date.
Hi......
Don't miss this...I went to the last 2 cruises to the GOR and both days were fantastic... I also live in the Northern Suburbs (Bundoora) so see ya at the Western Meeting point.
Rowan
Count me in.....sounds awsome!!. New"ish" member an havent been on a cruise and am looking forward to it. I'll be adding to the Geelong members meeting at Ponds. Sounds like it'll be a big turn out, definatly bringing the digital cam along.
Well i havn't been on the forums much latley been working before uni starts but unfortinunatly i will miss out on another great cruise i know everyone will have fun.
i spent last weekend crusing through the adelaide hills so i should be able to survvie with out a GOR run
have fun all be good
cheers
cya all @ mas
Since the dyno day has been cancelled at STI i guess im in. Im another cruise first timer so it will be great to meet everyone i havent met before (which is the vast majority of you).
Ill have a spare seat next to me if anyones interested, ill be leaving from the SE departure point. But be warned i always drive with the windows down, and i only have a tape player (thats how stock my car is).
    • I got a full sheet set of OEM copied stickers to replace all the faded engine bay ones, great quality too.  Came from England. Someone like that should be able to to make u up what u want so long as u have a quality image to show them 🤷🏻‍♂️
