Bonnet Hinges - $20
Rear window wiper motor - $30
Fuse box area aircon vent - $60
A/C Condensor Fan - $50
Centre console "tunnel" type thing at rear of radio to floor? - $45
Aircon Temp Sensor - $20
Boost sensor - $15
Side Repeator lights ( Orange - Amber ) $20ea or $30 both
Pedals Accelerator, Clutch, Brake with all brackets $100 for the set "GTR" rubber in good cond.
Odometer Cable - $20
Air Con Control (DIN size unit under radio) - $80
Std. Exhaust Manifolds - $70
Exhaust temp sensor - $20
HKS "Mushroom" Filter kit fits to std. AFMS - $70
ATTESSA oil Res. - $30
more to come msg me on 0422 648 745 prices neg. message me with listed price and your offer.
Buyer pays for postage if Aplicable.
-Daniel
https://www.sau.com.au/forums/topic/343469-r32-gtr-odds-and-sods/
RB26DETT Valve caps - $40
Thermostat housing $30 and other side casting for radiator $30 also
Seat belts $200 set or $60ea
Std. RB26DETT ignition Coils $100
Pwr Steering Fluid Res. W/ Lid and wiring - $50
Charcoal Canister (Transaction Aus Carbon) -$40
Coolant Res. - $50
Winscreen washer res W/Pumps - $70
Some Std. FMIC piping $40 Lot
Wiring loom (Cabin Fusebox loom) W/fuse box and all fuses/relays - $150
"Twin Turbo" Pipe RB26DETT - $80
ABS Unit $200
Aircon Vent (Centre Dbl. vent) $70
Fuel Cap Cover W/ hinge (Gun metal Grey) $20
Starter Motor - $40
Bonnet Release Cable - $20
Tail Lights - $70 ea
Boot lid Rubber Seal - $40
Engine Mounts L + R $40 ea
Passenger side reverse light - $40
Cam Position Sensor - $50
Std. Cam Gears - $30 Pair
Std RB26dett Cams $180
Fuel Rail - $60
A/C Condensor - $50
Pwr steering fluid cooler - $30
Flywheel - $100
RB26DETT Sump and diff $180
Steering column W/ Ign Barrel + Keys - $300
Engine Crossmember - $150
Steering Rack + lines - $100
RB26DETT Head Studs - $60
Accel. cable - $20
Passengers A pillar - $30
Clutch Fan - $40
Boot Hinge + Springs - $60
Front Sway Bar Std. - $60
Passenger Steering bar thing from rack to hub - $20
Air Comp. - $60
Passenger Door (Red / Burgundy) W/Window, no card or handle $200
Drivers door (Gun metal Grey) Wwindow, no card - $210
RB26DETT Cylinder Head 1 piston gave up and shattered so 1 cylinder has mashed valves and rough suface may be repairable -$40 pickup only
RB26DETT Block (1 missing piston, Bent rod, and has bashed through that sleeve) 5 pistons left with rods, Crank and large pulley part open to offers
Throttle Position Sensor - $40
Injector wiring loom cover (Black plastic) - $20
Rb26dett dip stick - $10
Centre Light (Roof) $20
Dash Cluster - 180kms model, $100
Dash Surround, with all switches gd cond no cracks $100
BUMP! please read through carefully, AM WILLING TO CUT PRICES BY A FAIR BIT! message me an offer need to get rid of all this soon too much clutter
Edited by SSSLOW
Adrian P - Should still have them haha any idea how to go about getting them out?
Das Kamu - Sorry about inbox, i have just deleted a load now, yes I do have the LH seatbelt PM me if your still interested and a price?
  • 2 months later...
Hey - do you have the drivers side or passenger seat belt clip ?
Will buy the whole drivers side seat belt and clip $60 if thats the deal...
- posted to ACT.
Edited by Sinista32
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
