Is It Worth For Me To Keep The Skyline 1993 R33 Gtst For The Next Few Years?the Maintainances Cost Seems High...please Give Me Some Opinion~~~~~~~~~~~
Hey guys,
I just bought a Skyline R33 GTST 93 model. I bought it in a good price, however, when i go service check for my car, it estimately cost me like $2000 for the intial fixing cost. Mainly is the suspension and brake system. It is a 93 model, it makes sense that it cost so much in the maintain. I would like to know is it really worth to keep it for a long run? I just use my car for normal run. I really don't want to pay too much in maintainances after i pay that $2k for a major service. Any opinion guys??
Edited by bbb10241347
the costs would only be that high because there is something worn or damaged that needs replacing. general maintainance costs are no different to any other car. you just change the oil and the filter and replace any things that need replacing. most of your services shouldn't cost more than $100 if paying a workshop to do it. the only other expensive service is the 100,000km service where you need the timing belt replaced, but as i said, that is only done every 100,000kms.
might be worth finding out exactly they are doing for the $2000 to make sure you aren't getting ripped off.
Hey guys,
Sell it and buy a push bike? hahaha... I'd keep mate, if you have waited a while to buy one, why sell it so soon? just look after it, and see how you go??
Get a list of what they want to fix and post it up here. That way we can help you out to see if its urgent or maybe you dont have to do it all right now.
since when do you post useful responses!
hahha
he is right though.
They charge me that much becoz they have to change the Front Arm Burshes (400), Outer Tie Rod End (150), Rear Shock (550), Front Brake pad and rotor (600), Coolant flush (120), Steering oil flush (100), Brake fluid flush (100), Fan belt change (180), Re-alignment (70)....Well,its like a really big service to the car....and i have ask many ppl opinion about it. It just cost too much to fix. But I mean, after i fix all this, there maybe other problems raise up. So, thinking of is it worth to keep it~
550 to change 1 rear shock? That sounds excessively expensive pretty sure you can get a new shock for like 150 and install shouldnt be anywhere near 400
haha those prices are steep as, and half of them probably aren't even necessary. are those prices from a Nissan dealership or somewhere else - have you taken it to another place to get a second opinion?
i'm guessing it was for both shocks, and the install on them is a bit of a pain. gotta pull the parcel shelf out.
Yea,price is similar to most of the place, I just check it. is it worth to pay off or just sell it...tht's wt i really want to know. If the 93 models car running ok with less maintainance after i fixing it. Tht will be great.
once you get those issues out of the way then it shouldn't cost much to maintain. as i said, it's no different to any car really. cost wise it would be the same as a 97 model to maintain. it would also be pretty much the same as an 89. it would also be pretty close to how much it would cost to maintain a commodore or even a corolla.
pretty much everything you have had done won't need to be done again for quite a while. coolant will generally last 3 years, unless you drive a lot of kms every year. power steering won't need to be done again for quite a few years either. the steering and suspension and brake stuff should also last quite a few years now as well. all you should need to do now is just change the engine oil and oil filter every 5000km, which should cost you about $60, depending on the quality of oil you use. if you pay someone to do it then it will be up around $100. you may have other things that need replacing in time, but that comes down to the condition of the car, and is something that you could have to do in any car.
Thx for yout time typing this.After reading this. I feel a bit confident to keep it. Coz i used to have sport car around 97,98 and never have any problem. Just becoz this time i got a 93 model and feel a bit worry~lol~but yea, you are rite, I mean i use my car normally, shouldn't be any drama. And the GTS25T engine is pretty strong,don't they? :D
if you try and sell it you will loose quite a bit of money, as unless these problems are fixed, it wont pass a road worthy, and then you cant sell it registered, and no one will want to pay much for an unregistered skyline, especially with the state of the market these days
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
