but no real benefits?
Take some pressure readings along your exhaust before each component. If you have more than a few psi of presssure anywhere then you have power robbing restriction.
If you have restriction... remove it.
Personally I would go bigger pipe size for that turbo, unless it's a straight pipe with no mufflers.
Cheers
Justin
https://www.sau.com.au/forums/topic/343649-zorst-3-vs-4/#findComment-5541205
it isn't going to make it worse though
This is what I think, Although after some discussion with some really experienced builders, they think this is not the case.
It is thought that having to big of an exhaust does effect torque. Personally if i was chasing every hp possible i would do what 'XRATED' said, just like inlet lengths need to be tuned so does the exhaust. although turbo cars are no where near as fussy as other cars (after the manifold) it would still make a couple of hp difference.
Edited by phat_man
https://www.sau.com.au/forums/topic/343649-zorst-3-vs-4/#findComment-5542155
It isn't like an NA car where tuned extractors and smaller pipes to maximise velocity help, on a turbo car the exhaust is under such a high pressure due to the collector you want it as free as possible, I really wouldn't doubt if a straight pipe helped power over the entire graph.
https://www.sau.com.au/forums/topic/343649-zorst-3-vs-4/#findComment-5542194
With turbos, you just want to get the gasses out of there as fast as possible, any back pressure post-turbine will slow the turbine down.
With long exhausts on a street car, stepping the size of the exhaust down helps maintain velocity. For example, a 4" dump in to a 3.5" front then 3" catback would probably work quite well (or maybe 2x 2.5" so you still get the volume but you increase the velocity).
https://www.sau.com.au/forums/topic/343649-zorst-3-vs-4/#findComment-5542220
read my post.
you need 4" for 400-440 (t04z) range.
3" will be hurting that setup.
Not true at all, at top end when you are making that kind of power a whole lot of exhaust is bypassing the exhaust via the wastegate...
3" on 26 with T04z regularly make between 430-470rwkw
https://www.sau.com.au/forums/topic/343649-zorst-3-vs-4/#findComment-5542225
It really depends on your power level.
I'm running a 3in exhaust from cat back. and putting out 350rwkw
i've got a 3in decat, 3.5in muffler and a aftermarket front pipe.
its a pretty straight design with minimal bends. it does the job!
i think if i were heading for closer to the 400rwkw mark i would be looking into a 4in exhaust or at least a 3.5in
i also think that some people get confussed thinking that a bigger exhaust will allow faster spool up, but that's only true if the current exhaust is a restriction at that rpm and load point, which i would higly doubt that a 3in is a restriction at 4,000rpm. it'd be a restriction up higher and when 25psi or more boost starts pumping through the motor.
it might make your decision easier to listen to what a car with a 3in sounds like vs a 4in exhaust, i like my 3in because its quiet enough to not attract too much attention and if flows well enough for my needs.
https://www.sau.com.au/forums/topic/343649-zorst-3-vs-4/#findComment-5542232
Garrett engineers on their website clearly state that the less restriction after the turbo the better. Sure this needs to be weighed up with physical limitations and noise levels etc. But a greater flowing exhaust can only improve response and top end power. Obviously, whether its even noticeable depends on your power levels but at 400rwkw I think it would be very noticeable.
Just because some cars manage to get 400rwkw through a 3" exhaust doesnt mean they couldnt be a heap better with a larger exhaust.
Min 3.5" IMO
https://www.sau.com.au/forums/topic/343649-zorst-3-vs-4/#findComment-5542263
Very interesting point, makes sense.
https://www.sau.com.au/forums/topic/343649-zorst-3-vs-4/#findComment-5542271
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
    • Sounds like a misfire. Check fuel pressure and don't even think about going into boost while it's like this unless you enjoy engine rebuilds.
    • Just. Gasping. Here. Just. Gasping.
