hey guys , just wondering if someone either profesional or backyard who rebuild engines , machines them ect would mind me hanging around after hours and on the weekends to try and learn a bit about engine building? really keen to help out and learn about engines ?? if not any ideas who i could aproach?
https://www.sau.com.au/forums/topic/343961-random-engine-building/
i just finished building a 308 for a race car your a week too late ,have another 308 thats almost finished as well for my own race car on the stand but im not in a rush just yet to put the heads on that one .
what side of town ru on ?
cheers dean
I'm the same. I've learnt lots by doing heaps of work myself over the years aswell as lots of reading but really wanna learn how to assemble a 26 from the ground up, not really into paying workshops for something I could spend a few hours learning how to do something that I don't even know if they have done it correctly.
Next year I'm actually planning to buy a tig welder and get practicing at welding. Something im keen to try and learn.
I grew up with family into rallying, drag racing, circuit racing ... all in cars and on bikes. So it was a no brainer that I was going to inherit those genes. Rebuilt my first 2 stroke motor at 14, and was servicing the family cars at 16. My first car was my uncle's TC Cortina street/drag car. Did lackey work in workshops from 16-18 then went on to spray painting. Applied to be a RAAF aircraft technician, but an injury at the time stopped me, so settled for working on cars. Had a real head and heart for it back then ... now I just got the head for it. Got fed up with working on cars for a job, so now I just tinker with cars for a hobby as its more enjoyable.
I've done some stupid projects over the years, including a 13B 1600, supercharged SR20DE in a 200B, CA18DET in a 1600, and many other dumb projects that should never have been built (turboed CBR1000 drag bike being one) :) I do all my own work on my cars and bikes, and have done so for more than 20 years. I've even helped out a few SAU members with their cars and shown them a few things to learn along the way too.
I'm all for people learning to DIY. :(
I have a RB25DET out of a S1 here that we can build :( it has a bit of damage but keen to get it up and running and then possibly look into getting a rolling shell :)
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
