I hope for some suggestions, or maybe even a referral to someone who may know wtf is going on. Short story is made a stack of mods, twins, z32s, fc, inj, pump, cams, reg, splitfires, cooler, etc. car was tuned, started perfectly, but was very disappointing in the top end.
So i had the car re-tuned by another dude with 1000cc ID's and removed the resistor pack. Tune is awesome, good on fuel, smooth idle, very linear power delivery, and decent final figure. However the startup is now crap. Cold start is quite good, also when you turn the car off and on again within 5 minutes. The problem is when i park the car for anything between 30mins to 6hrs and try start it again. It cranks forever (30+ secs), i have to pump the accelerator, and just barely starts and struggles to get up to normal idle.
To the tuner's credit, he has spent hours on it, involving an electrical engineer and can't crack it... Injectors have been flow tested, voltage tested, pump has been tested, crank signal shows on the fc controller when cranking, plus heaps of other stuff. The tuner is a champion and has probably tuned most sydney cars on this forum, so i don't think for a second it is down to his ability, has to be some weird ass quirk...
PLEASE HELP!!!
https://www.sau.com.au/forums/topic/344702-bch-wont-start/
PLEASE HELP!!!
If your having to hold your foot to the floor to get it started i think you might be using the flood control of the power FC which means you are getting to much fuel while cranking use your hand controller to trim this, I had this exact problem with my GTR and playing with the hand controller fixed it.
Goodluck.
https://www.sau.com.au/forums/topic/344702-bch-wont-start/#findComment-5555658
Goodluck.
Thanks for the feedback mate. I haven't held it flat to the floor, but i have been pumping it for like 30-45sec to get it to start... I will try holding it flat and see if starts quicker, if so, than maybe it is too much fuel.
https://www.sau.com.au/forums/topic/344702-bch-wont-start/#findComment-5555708
My car is the exact opposite!
Every morning or if the car has sat for a long time, its a B**th to start. I have to turn the key one shot. If i leave it in ignition till the fuel pump runs and cuts out, i have to crank it really long and depress teh gas pedal. but once it has warmed up or even after a few hours of sitting its starts like a charm. It only does this when it sits for too long like in the mornings or in the evenings after work. Anything i can do to solve this? Fuel pressure too high?
https://www.sau.com.au/forums/topic/344702-bch-wont-start/#findComment-5555843
No smoke... U guys have nailed it, on first impressions. 4 starts so far, and every one of them a winner with foot flat to the floor!
What is odd about this is that the tuner tried leaning it right out and adding heaps more fuel, both ends of the scale with no luck. He and an electrical engineer went right over the car for like 5hrs and found nothing helped. He is prob the best known tuner on this forum too, so he is definitely no rookie...
Thanks guys, i will take this idea back to him.
https://www.sau.com.au/forums/topic/344702-bch-wont-start/#findComment-5557327
I had a similar problem with my R32 and turned out to be fuel pressure was too high, try adjusting ur fuel pressure regulator
if u have a fuel pressure gauge on it, if not take it to somone who can. On my car when the ignition is turned on
it is running 50psi. starts up after a single turn of the key everytime..
Hope that helps in some way
https://www.sau.com.au/forums/topic/344702-bch-wont-start/#findComment-5567640
What timing is it running at start?
The reason it is starting with some throttle is possibly die to the throttle allowing more air to enter the combustion chamber, which implies too much fuel while starting. Have you looked at any form of temperature correction in the maps (don't know about PFC, but Wolf has a seperate temp compensation map).
https://www.sau.com.au/forums/topic/344702-bch-wont-start/#findComment-5568153
  • 2 months later...
Hey guys, digging out an old thread, i forgot to check back on this...
It is running BP98 now, no E85 as yet.
I don't believe the PFC has a temp compensation map, but i could be wrong...
Trent, i will forward through my map as soon as i can download it.
https://www.sau.com.au/forums/topic/344702-bch-wont-start/#findComment-5669701
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
    • They have said food will be limited. Mainly meat pies and sausage rolls from memory. But they have a coffee van!
