Hi
I came across these the other day when looking for wheels to put on my RS4S when it gets here. Has anyone seen/had them on a car or any other wheels of this brand?
I think they look pretty nice, but I'm yet to see them in the metal, or see them on a car.
http://www.oxwheel.com.au/uploadfile/10010..._1947512142.JPG
Thanks
Tim
https://www.sau.com.au/forums/topic/344832-ox-wheels/
they look ok!
check how much they weigh. i would imagine a lot if they are cheapish wheels
This may be a dumb question, but how much should they weigh? Is there an easy way to find out other than getting the shop to weigh them for me?
https://www.sau.com.au/forums/topic/344832-ox-wheels/#findComment-5557752
gday
so what size and offset are you looking at and do you have any other rims in mind?
also noticed your in launceston, wouldn't mind meeting up one day.,
Hey
I'm looking at 18s, not sure about offset yet, I want to try and keep a bit of depth to them which is why I'm keen to see them on a car or in the metal so I can get a better idea what's possible.
Yep, in Launceston so happy to meet up some time. Hopefully should have the car in mid-Jan (it's on the boat from Japan next week), so looking forward to that!
https://www.sau.com.au/forums/topic/344832-ox-wheels/#findComment-5558099
Check their website for sizing and weight. Tangles has these wheels in 18s, i think. Do you have a RS4S or RS4? Wider rear track needs offset to be higher at the rears. Swapping cradles sorts that. I got cr kais 17 x 9 +23. IMO get good tyres and rims that fit your car well. Try not to use spacers.
Edited by dirtyRS4
https://www.sau.com.au/forums/topic/344832-ox-wheels/#findComment-5558100
Its going to be a long couple of months for you then.
I have 18x8 with 30 offset and my tires are 235x40, when i lowered the car i needed 15mm spacers on the rear but after getting adjustable camber arms and
bringing the camber back to standard i didn't need the spacers any more.
When you get yours down here your welcome to have a look and try my rims to see how they fit, I am pretty sure they didn't fit with standard hight,
the problem was the rims where rubbing against the coilovers which are a lot thicker then standard so i guess it all depends what you have on your car.
https://www.sau.com.au/forums/topic/344832-ox-wheels/#findComment-5558205
I'm getting an RS4S Dayz edition. I can see some stats on the webiste, but no weight I don't think.
http://www.oxwheel.com.au/main/product_sho...7&cataid=33
The plan is to get wheels and tyres that fit well, I don't want to be mucking around with spacers or have bad fitting rims. If these ones don't work out, I'll try and find something else.
https://www.sau.com.au/forums/topic/344832-ox-wheels/#findComment-5558213
Haha, it certainly will be a long couple of months, particularly once the car reaches Oz and is getting complied etc, so close yet so far!
Coming and looking at different rims sounds good. The more I see the more idea I will have.
Next question, where is the best place to get them done in Launceston?
https://www.sau.com.au/forums/topic/344832-ox-wheels/#findComment-5558219
IMO dont fck around too much with the camber. With coilovers or lowered the rear wheels naturally tend to lean in, and result in chewing the inside of the tyres. This occurs because it physically works against the multi link independant rear suspension of the stagea.
Ppl use camber kits as a cheap workaround for looks, but dont reliase they are just complicating suspension components when they should concerntrate on strenghtening them. Let me emphasise again - buy rims that fit with a 9" width and good tyres. Offset and disc type is the key to a successfull fit. Remember always equate fitting bigger brakes behind them. :(
Edited by dirtyRS4
https://www.sau.com.au/forums/topic/344832-ox-wheels/#findComment-5558240
anything to suit gtr will fit
the same size all round is a must
18x9 +15 would be a good start
Cool, thanks for that. Definitely looking at the same size all round. Is the fact that they are 18x8.5 rather than 18x9 going to make much of a difference?
https://www.sau.com.au/forums/topic/344832-ox-wheels/#findComment-5558408
Basically, an 18x8.5+15 will sit 1/2 inch further inside the guard than 18x9+15.
https://www.sau.com.au/forums/topic/344832-ox-wheels/#findComment-5558413
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
    • Assuming your brake pads are not worn right down, I'd add a little brake fluid. Is there any sign of a brake fluid leak?
    • Hello all,  I need of some help. On my drive home my handbrake light lit up and started flashing. When I got home I checked my handbrake sensor under the centre console and nothing seemed out of the ordinary. I have scanned my car via the consult port, no codes shown. Checked my brake fluid as well which is half full. Tried unplugging the brake master but it didn't change anything. Thoughts on what it could be? The master float doesn't seem to be stuck. My car is an 1998 ER34 sedan GT. No hicas but has ABS Photos below 👇🏾
