Hey guys,
I tried fitting my replica R34 GTR wing, but the sale did not include the screws. The replica appears to have screw holes on which the previous owner used to attach it to the boot lid.
From my observations, the factory spoiler has 2 threaded studs fixed to the spoiler (2 on each end), effectively held on by four nuts to the threaded studs under the boot lid.
Is there something I can buy off the shelf?
https://www.sau.com.au/forums/topic/345068-replica-r34-gtr-wing-screws/
Okay guys. I think Z in the picture is what I need. Any idea's on what it's called? It would be easier if I could identify what sort of screw it is so I can purchase it.
You may be able to, but if they are push cast into the wing (doubt it), or if the hole is brittle the wing mount may be damaged...
If they are screwed in, you can remove by putting 2 nuts onto the stud, tighten the nuts into each other then, undo the first nut you put on with a spanner etc.
This will usually undo the stud.
Good luck!
Alright guys, it appears that standard non-tapping screw with a big washer works fine. I went to a panel beater (Sheen Group in Hoppers Crossing) and asked, he gave me four screws with washers for free. Nice chap that one.
