Still at trying to solve my boost issue.
When you take a STOCK S1 BOV off, should there be no leak if you blow (no sex please) into it, which is SFA pressure. I have two BOVs here and both have a slight leak when shut. Is this normal??????
My prob is that sometimes when slowly accelerating it will boost to 1-3 psi then die inthe arse back to zero boost.If you pull over and try to rev it wants to cough and die, sometimes you can save it, but not always. Turn the key off and it starts Peter Perfect, and runs till next time it spits the dummy.
https://www.sau.com.au/forums/topic/345334-leaking-bov/
The factory BOV is designed to leak slightly at idle.
If you have a pressure source on the top of the BOV identical to the other side it won't open.
Have you got an AFM issue? Poor plug connection, dry/cracked solder internally on the pins?
I had a diagnostic, while driving. AFM,coilpaks, A/F mixture, spark, plugs all checked out OK. I feel i am looking for a leak somewhere.
Stick my head under the bonnet again.
https://www.sau.com.au/forums/topic/345334-leaking-bov/#findComment-5563651
I should clarify the leak is mostly from that small hole on the face of the BOV to the side of the port.
I figured that out. duh. my bad.
As Mike says it is an air leak and I am pretty sure its coming from where the AAC valve is. The problem now is I will have to take the plenum off to fix it.
To do this properly you need two slabs (at least) and two packs of bandaids. And probably a new plenum gasket.
Two slabs $70, Bandaids $10, gasket $98, total $178, plus extras say $200.
Might as well get the cam covers off and have them polished.
https://www.sau.com.au/forums/topic/345334-leaking-bov/#findComment-5563786
You could try resoldering the AFM pins. It is about a 30minute job and it might explain why the issue is intermittent. Leaks tend to be constant in my experience.
That is what i cant understand. When the engine is idling you can hear a leak. Rev it a bit and it seems to go away.
Not 100% sure what you mean about resoldering the pins. I can solder tits on the Tin Man so if you give me a pic I can do it.
https://www.sau.com.au/forums/topic/345334-leaking-bov/#findComment-5564221
do you think it could be the noise of the air being sucked through the AAC valve, i can see how it could be mistaken as an air leak, especially since yours in under the intake manifold, kind of tricky to get to and tell for sure.
to solder the air flow meter have a look through this tutorial -link to thread-
https://www.sau.com.au/forums/topic/345334-leaking-bov/#findComment-5564286
What about getting hold of one of the ECUTalk displays; you can watch AAC and AFM voltage levels and see if anything goes haywire when the car cuts out? It also logs max values too. If it's AFM the AFM value may go either to ~0V or ~5V when the problem occurs.
https://www.sau.com.au/forums/topic/345334-leaking-bov/#findComment-5564358
There is noise from the PCV valve at idle that will disappear when you rev it. Does a FFP have a PCV still attached? I guess they delete it so perhaps not that?!!?
The afm is easy to solder....even I can do it and I am definitely not skilled in that department. The biggest issue is gouging out the silicon as it runs a bit deeper than you think. Once you pop it open the pins often look ok but hit them up anyway.
I have fixed 4 afm's with intermittent issues, stalling, misfires etc. It might be something else in your case but there is little downside in re-soldering.
https://www.sau.com.au/forums/topic/345334-leaking-bov/#findComment-5564380
Yes. The FFP has a dedicated line to the PCV. It could be that. I will have anot6her listen tomorrow.
https://www.sau.com.au/forums/topic/345334-leaking-bov/#findComment-5564643
The cam cover to manifold PCV has a 1 way check valve. When the manifold pressure is less than the cam cover, ie under vacuum, oily gases flow from the cam cover into the manifold. When the manifold pressure is greater than the cam cover, ie under boost, the check valve seals, and any blowby pressure is vented out of the other PCV breather pipe back into the turbo inlet. I think that explains what you want to know?
Edited by zoomzoom
https://www.sau.com.au/forums/topic/345334-leaking-bov/#findComment-5564895
Found a leak in the fuel PRV hose. Still hear the noise at the AAC but that could be normal as the hoses and fittings meander a lot.
We had road tested the AFM, A/f ratio and these were normal but the car did not play up while doing it.
After fixing the PRV leak I am sure the running is much smoother.
Test will come when I go on the cruise.
Edited by 66yostagea
https://www.sau.com.au/forums/topic/345334-leaking-bov/#findComment-5567411
Back to square one. Yesterday while L plate son driving, engine went into limp??? on the Gateway motorway. Car was running perfect for about 80ks, then poof. Got to the edge of road after cutting across lane. Turned off, started first kick, and ran sweet. On the way back, alone, it tried to limp about 6/7 times but by now I can handle it. But I considered it unsafe to take on the cruise. Bugger.
Fitted another AFM last night and will test over the next two days.
Found a leak where the PCV valve is in the L/H cam cover, but want to check the AFM first. Must do things one at a time otherwise I will not know what is the cause.
https://www.sau.com.au/forums/topic/345334-leaking-bov/#findComment-5569212
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
    • And yes with a full tank it will hit limiter free revving or driving 6B6CDF6E-4094-426D-A9CB-6C553475FE36.mp4
    • One way of putting the fuel surge idea to rest, is that even when in neutral/clutch in or free revving it still has the same issue, it can’t even get to limiter (7800) so to me that says it can’t be g force, I’m not trying to argue I just want to find the f&$king issue 😡
