I'm selling my series 2 1996 GTR LM V-Spec. This is one of only 98 ever made as a special edition.
The car was personally imported early 2006 with 68,000km's on the dash. The car currently sits on 109,000kms.
I have the original auction sheet in which it was a grade 4 with grade B interior.
The original importer also completed a full major service at the time of import including new timing belt, water pump etc. Full service and all oils changed (both diffs, engine, gear box) at hyperdrive on the 19/05/2010.
The car has the following modifications:
Nismo Rays LM-GT1 Wheels 18x10 all-round with quallity Toyo Proxe 275/18/35 rubber. Tread still like new on all wheels.
Power FC + Hand Controller
HKS Hi Power Silent Exhaust
Tomei Cam Gears
19 Row Oil Cooler with Relocator
GReedy Profec B Boost controller
GReedy Turbo Timer
Autometer Boost Guage in PSI
Factory rear carbon spoiler
Factory side GTR Decals
Factory front bonnet Lip
RB26 Clear Timing Belt Cover
Custom Pod Heat Shield
Nismo Fuel Cap
Nismo Radiator Cap
Cold Air induction to Pod's
Apexi Induction Kit
Nismo Clear Side and Front indicators
The car now has brand new 20% tint all round.
This car is a genuine collectors item in its original Championship Blue (BT2) colour which can be verified by the engine bay build plate. Overall the car is in very good condition, paint is excellent and interior is very tidy. The pictures don't do it justice, it really needs to be seen.
I only ever run the car on 98 and it's always warmed up and cooled down before and after driving.
If you have any questions please contact me on 0410 039 043.
$24990 ono.
Thanks.
Edited by gersfan
https://www.sau.com.au/forums/topic/345428-r33-gtr-v-spec-lm-limited/
aww man, if only this was for sale when i was looking i would have snapped it up straight away.
great looking car man and a bargain too!
wow, that is nice, pity its so far away from most of the buyers which I'd say would be on the east coast, although someone over there in the west will no doubt pick it up and be very happy with it ......
absolutely love this shot of it, looks not too dissimilar to the wrx blue colour .....
Edited by Simon_Koala
looks like an awesome ride... couple of q's...... does the air con still work, and what is the power out put (do you have a dyno sheet) cheers
http://www.yourfilelink.com/get.php?fid=589499
Air-con works fine. I haven't had it on a dyno but it's a pretty conservative tune, ping is extremely low the rev limit is 7k although you can increase it with the controller if wanted. I would guess 280-300 awhp.
When I bought it I had plans to finish the exhaust, upgrade the turbo's and retune etc but my life has changed direction so modifications have stayed the same as when I got it.
And navan that's a nice 32 you have
Edited by gersfan
open to swaps? or are u after cash.
vy clubsport.
I'd consider swaps but it would need to be cash my way and a car I don't need to fully insure
thanks though
Hey mate my aunty lives in Perth and I am going to get her to come have a look at the car if it doesn't sell by sometime next week. She is a mechanic so she can do all the scouting for me while she is there which helps. Beautiful car, I am chasing a 32gtr but this is a unique example that I would like to own for awhile.
just a couple questions. Did the car come with the powerfc installed so the tune was already on the car? If not can you get a dyno sheet for it.
Sweeeeeeeeet
Sweeeeeeeeet
It already had the powerfc and tune when I purchased it, I don't have a dyno sheet.
Serious buyer with money can drive it and feel it for themselves, I'm guessing 280awhp but I don't know. Is capable of much more with a solid tune and full exhaust I'm sure.
I've had a few enquires about swaps so I'll just put this out there. If I was to take a swap if would need to be worth 10k max, and preferably a 4 cylinder.
Thanks
Edited by gersfan
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
