If you liked that one, you gonna luuuurve this ex-R32...
Lllllllllook at the back window ferkristsakes! Have some people got no taste?
... no.... no. I don't like it... It's..... it's..... HIDEOUS.
having being into, studying & working around design for a few years now i'd say that they have sinned against nature.... out of proportion, mismatching shapes, different decades, etc
the fat guards are sorta phat though
    • I got a full sheet set of OEM copied stickers to replace all the faded engine bay ones, great quality too.  Came from England. Someone like that should be able to to make u up what u want so long as u have a quality image to show them 🤷🏻‍♂️
