You want the largest gap that your ignition system will allow for the best burn.
If you develop a missfire you can gap them down (or buy pre gapped plugs) until the missfire stops. Or you can look at your ignition system and see whether it needs time for a replacement.
Standard maximum gap that spark plugs usually come in is a 1.1 gap represented by -11 on the end of the part number.
Most people run a 0.8 gap due to running high amounts of boost or having poor ignition systems.
im running a microtech with 6 bosch coils and a x6 ignition module what should i use?
Depending on how much boost you are running I would try a 1.1 gap and see how you go.
For reference I run Splitfire coilpacks with 0.8 gap NGK plugs (7 heat range) and don't get a missfire with 20psi of boost and nitrous.
Once the plugs get a bit fouled up, then it will miss.
Hence I changed them every 5000km.
Stock boost 1.1, if you get it misfire at high rpm then go down .5 at a time till it doesnt misfire at high rpm.
I was running .8 at 15lb which seemed to work well, the bigger the gap the better so dont go smaller than needed.
There is a thread on plugs and gap size in the forced induction area.
Go copper and replace them every 5 000k, coppers are as cheap as chips.
The expensive ones are made to last along time but they give up performance after a while.
My 2 cents
    • Just had this happen to me too.  R32 GTR.   Also broke "just before going out onto the track" - someone up there is looking out for us... Very scary since I was about to do a narrow street course with zero run-off and curbs everywhere. Many people on here upgrading to billet uprights and R35 bearings?   Or buying new OEM knuckles?  I am not keen to replace with another s/h 30 year old fatigued part.
    • Top off with distilled water and see what happens. If you keep losing coolant then you know to start looking.
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
