  • Replies 59
2rismo's time was the 13sec
From memory he's running about 200rwkw + 50hp nitrous :wassup: right Adrian ?
With some nitto's or BF's you got a 12.7sec begging
BF Reviews: http://www.carreview.com/Tires/BF%20Goodri...rx.aspx#reviews
Comp T/A's Specs: http://www.bfgoodrichtires.com/assets/pdf/...drag_radial.pdf
Personally i'd be far more happier doing consistent 12.7's all nite than 1x low 12sec and 4x mid 13's. No point going to the 1/4 expecting to drop half a second in 1 nite.
I agree but why no go all out on one pass and then repeat that for consistency?
Just had a thought.... What's the quickest that ANYONE has gone on a std turbo'd (non-hi-flowed, ceramic wheeled etc) GTS-T???
2rismo, what tyres were you using?
Sh1tty sh1tty sh1tty Pirelli semi-slicks that had gone off. They're really designed to run @ 48psi and go round and round tracks not straight up for 400m.
BF's coming (fingers crossed for Jamboree in March).
im really interested in nitrous mate. wat kit are u using? and how much was it if u dont mind me asking.
Kit is a butchered and bastardised mess. 3 different Nitrous companies' products involved. (NOS, OzRace and ZEX) as well as the ancillaries like F.P.Reg, lines, fittings etc. Couldn't really give you an idea of price on that but a full kit with bottle shouldn't cost you more than 1300 bux. NOS, ZEX, OzNos are all about that.
In short, I have everything crossed to go into deep-twelve-country by just changing tyres and switching the gas on from the launch instead of from 2nd gear.
Adrian
Fair point, but if the car hits a low 12 whats going to stop it from doing it again?
I remember someone one the forums claiming a 12.9x with std turbo. I also know of another who claims 12.6 with stock turbo, but the only thing stock was the turbo.
Take a look at your own passes of late for example. You have done about 5+ 13.4-13.5's and then a 13.0 and a 13.1 so what I mean is rather than trying to do 1x 12.2sec and then rest all low-mid 13's i'd personally be aiming for nothing 'slower' than 13.0 (ever) but occassionally dip into the mid-high 12's when you get a good clean run (which as im sure you are aware is not possible on 'every' run due to a bad launch or missed gear etc etc) as your next 'step'.
I just wouldn't be going to the track aiming to knock 0.5->0.9sec off "just like that" because the mph says its possible.
Anyhow lemme know when ur back at WSID with some decent tyres and i'd be very interested in watching again :P
If it was that easy many more people would be doing it.
Think about it... you have 12-14sec to do what u gotta do. A minor 0.1-0.3sec stuff up anywhere along that 400m is gonna ruin a good time.
I just think consistency is the key to a 'quicker' time. With a 115mph TS a 12.1 flat would not be out of the question thats a whole 0.9sec faster than what has currently been done :headspin:
    • Sounds more like what Brad said, that it's mainly transfer. What pad bed in procedure did you use, and did you replace/machine the rotors, or just swap pads?
    • The stutter is almost entirely in the pedal. I don't feel the brakes release and reapply as you would with ABS engaging but the pedal feels that way, without the brakes releasing. It only lasts for less than a second and the pedal is fine again. It's hard to explain, sorry.  I'll get under this weekend and just double check everything is tight. Fluid is at max where I left it.
    • What bedding in procedure did you use?   When you say stutter, what exactly do you mean? Like it feels like someone letting go of the brakes momentarily and regrabbing them again to get you to stop? Re-reading your post, and that is what it kind of makes me think you're explaining, like theres a little bit of a jolt, likely just as you're reaching a stop. I've only had this issue once. And if its caused by what caused mine, you will want to get the car up on stands again and check it over. Mine was a case of a caliper mounting bolt coming out and letting the caliper rotate on the other remaining bolt and gave play in a wheel as it came to a stop. But not every stop either!
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - then entered a hotlap with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
    • Thanks, will do that.  Thankfully they still feel great.
