Hi guys, im having an issue with my R33 GTR whereby when i start the car up and the engine temperature is cool (car not driven for 3+ hours) when i accelerate there is a distinct stuttering - almost like there is some kind of fuel starvation going on. This only happens when the engine temperature is cold. Once i drive it for about 2 minutes and it warms up it responds perfectly. It has been doing this for months and is not getting better or worse. I have performed a full service recently and cant figure out why it may be doing this. I have also noticed that the oil pressure readouts are especially high during this period and am wondering if a) when the engine detects it is cold it runs in some sort of pretective mode so the engine isnt damamged in the warm up period or b) something is indeed wrong. Does anyone have any ideas what this is?
Cheers
Grant.
where the spark plugs changed at the service? also do you know what heat range they are, what gap they are and how old they are? it may simply be a case of fould plugs. they are fouling when the car is cold and running richer due to cold start enrichment, but as the car leans out a bit when it heats up, as well as more heat in the cylinders then it is able to burn the fuel better.
Yes the spark plugs were changed about 3 weeks ago down at unique auto sports. Not sure what heat range they are or gap either. I am running a Mines ECU which i've been told is one of the worst controllers for australian fuel + climate. Perhaps this is having an effect as well?
Skyines and GTR's in particular run differently while the engine is cold to protect the engine. As soon as the ECU detects normal temps and oil pressure then they run in normal mode and should perform properly.
I normally just let my cars idle until I get water temps up and oil pressure down and then they respond normally and it does not hurt the engine.
I thought MINES ECUs were tuned to Japanese 100RON fuel and non-programmable?
http://www.skylinesaustralia.com/forums/Mi...amp;pid=4976694
Yes, and as Charles said, warmups are essential.
I take it that what you're saying is, the car is even more temperamental since the plugs were changed?
If so, check the gaps and reduce if necessary.
Thanks for all your replies guys. I checked the service sheet from when the plugs were replaced and copper 6 heat range plugs were put in. I don't know enough about spark plugs to make a call on how they will affect performance when cold / hot but hopefully that makes more sense to you guys..
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
