20mm is a lot of movement for a 1piece. If you grab the yoke on the diff does that move back and forth the 20mm? if so that is u/s and will need attention.
If it was to long the workshop would have had a tiny bit of trouble getting it out which you said earlier they reckon if was fine, if it was to long it would either bottom out on the speedo gear in the back of the box or bottom out in the bottom of the yoke on the output shaft. They are designed to move a tiny bit up and down the output shaft to deal with suspension movement when under driving conditions.
Is it possible for you to check the 1 piece length next to a stock tailshaft? Or to even get the balancing on it checked?
If it was to long the workshop would have had a tiny bit of trouble getting it out which you said earlier they reckon if was fine, if it was to long it would either bottom out on the speedo gear in the back of the box or bottom out in the bottom of the yoke on the output shaft..............
The OP's sig says it's a GT4, so it won't have a sliding yoke at the box.
As a 2-piece, it would have had a conventional uni at the diff, a CV at the centre bearing and another CV at the box.
As a 1-piece, who knows what they did?
Either way, stuffed diff insulating rubbers won't help the prop shaft.
Is it a harmonic vibration? Like when you have a poorly balanced wheel/tyre?
Or is it a metal to metal vibration, like random banging?
If it's a speed related harmonic vibration, and it does it when in neutral and rolling along, it's your tailshaft/diff/axles. Now all things being equal (if nobody thrashed it without your knowledge) the diff "shouldn't" just stuff out. Not to mention they don't usually cause much of a vibration without a lot of noise associated with it. The axles etc, well they shouldn't have even gone that far back.
My subframe bushes are stuffed, and if you search Google, you'll see forums all around the world with this common problem. While causing other suspension anomalies, you don't get speed related vibrations, and again, not instantly after taking it to a mechanic.
I'd put my money on the tailshaft. Get it balanced, any gearbox/tailshaft place with a balancer can do it, have it checked. This is assuming it's speed related vibration with the car in neutral.
To check shaft length quickly yourself, remove the bolts from the pinion gear on the diff and push the shaft towards the box. When it stops, you can mesaure the length between the shaft and diff's pinion gear. I'd have to get the book out to know the measurement (if it even has one), but you'd probably want to see about 20mm gap. (< My guess) If it's like, 5mm gap, or around that, I could safely say that's probably too long, but even then it shouldn't cause a speed related vibration unless the gap was like 0mm and you really had to force it in..
If it's engine/rev related vibration when in netural. It's quite possibly the flywheel/clutch/plate/input shaft/etc. You'd have to have the box off to check this out.
Cheapest thing you could do right now would be to fit a friends shaft if you can get one, or get yours balanced. And if you don't care about taking it somewhere else, get it independently checked.
Good day :)
I can only describe it as a regular vibration (something related to rotation) which you could feel throughout the car Varies at different revs. It's nothing at all like a wheel alignment vibration. It was originally only going when in gear, but on a recent test drive after the clutch and flywheel were done it started doing it when it was in neutral and coasting as well. If nothing else thanks for some of the tips, I will talk to the shop it is going back to. I'll do some searching re subframe bushes etc as well, thanks for the heads-up.
If anyone in Sydney has a spare GTR tailshaft I could borrow that would be good. Unfortunately I cant check any of this stuff myself as the car is in sydney but I will get it followed up. Might ask for the tailshaft to be balanced, I find it hard to believe it is out of wack after 5 months though (new tailshaft) But at this stage I will check anything. The shop in canberra I had the car at initially was telling me the gap was 0mm, but the sydney shop said the tailshaft length was fine.
At this stage I am just getting really fed up with the whole run around, as I am getting two vastly different opinions from two shops that have worked on the car. One in canberra and one in Sydney.
Good day :)
I just read the manual. It mentions (as someone else did in this thread) that there are many alignment marks for the prop shafts.
Axial play is 0.6mm, so by rotating the shaft at the gearbox end with the gearbox in neutral, you should'nt see more than that. It mentions length, but for the stock 2 tube setup, which is 392+597mm. I don't know if that includes the centre bearing, yoke etc.
It mentions that on the gearbox AND diff, there are mating marks (or should have been drawn on there before it was removed.) So you'd have marks on the diff, gearbox, and both ends of the shaft. It also mentions rotating the diff 90 degrees, and try again, if not try 180, and 270 degrees. This is where the prop shaft mates with the diff.
At the end of the day, if it's balance was checked, is the correct length, and is mated to the gearbox and diff with the correct alignment, you could then eliminate the shaft.
Try this exact sequence as well. - Park. Gearbox neutral, clutch out, rev the engine, also, try holding at 4000rpm, then at 3000, etc. Do you feel the SAME vibrations at ANY stage during ANY of this?
Just remember being in neutral is the key. You can test the input end of the box by being in neutral while parked, revving engine, etc. You can test the output end of the box while the car is moving at various speeds, again in neutral. I can suggest that it will only vibrate during one of these testsm unless it's the clutch/flywheel, in that case you'd feel it on both tests. Eliminate.
Edited by GTRPowa
Have talked with the shop again.
There is the correct clearance at the back of the shaft, there is the correct clearance at the front of the shaft. Shaft has been balanced. Tailshaft is now being rechecked by the shop that built the shaft. Unfortunately the shop hasn't been able to find an original shaft that will fit my car. Due to it being a 4 door GTS4. They tried a few, which didn't fit 100% correctly.
I will double check with the shop re mating the shaft correctly to the diff, Which manual are you looking at? The GTR workshop manual?
When I had the car it did start to do it when I put it in neutral, however not when the car was stationary. I did test various rpm's and this didn't seem to do anything.
The shop is also getting my wheels checked, to ensure nothing is wrong with them.
At this stage if this does not fix the issue they shop I have the car at is looking at taking the gbox apart to look at it.
It could be the clutch or the flywheel, but I doubt it, as they were just replaced when first troubleshooting the car.
The only other data I have is the vibration seems to get worse the warmer the car is.
Well, it is looking more and more like my 5-6 month old tailshaft is bent. Turns out the builder of the tailshaft hasn't balanced it or checked it, and supposedly they have a reputation for making bad tailshafts, or tailshafts that fail after a few months.
Will find out more in the next few days after a proper report is done. But a certain well known shop in sydney can get stuffed for all I care at the moment, for their complete lack of customer service.
I do give the thumbs up to Award diffs and gearbox for helping progress the issue though. Would recommend them to anyone.
Well long story short it appears my tailshaft isn't bent but looks like it has been dropped on the floor, and the UV/CV joint was reassembled incorrectly thereby causing my vibration issues, its been inspected and reassembled properly. Will see how it goes once its been put back in. Not bloody happy...
I do give a thumbs up to Metroplitan Driveshafts in Granville and Award diffs for sorting out this whole mess. Would recommend them to anyone.
Drove the car back from sydney, no vibration issues, funny that... will be following this matter up with the canberra shop I took the car to, when all this bullshit began.
Thanks
Well im in that wonderful situation where no one wants to take responsibility for the stuffed tailshaft. While I have my suspicions looks like it would be difficult to prove anything.... I would still recommend the shops in sydney to sort any issues.
    • Any update on this one? did you manage to get it fixed?    i'm having the same issue with my r34 and i believe its to do with the smart entry (keyless) control module but cant be sure without forking out to get a replacement
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if something was binding the shaft from rotating properly. I got absolutely no voltage reading out of the sensor no matter how fast I turned the shaft. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if shttps://imgur.com/6TQCG3xomething was binding the shaft from rotating properly. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • perhaps i should have mentioned, I plugged the unit in before i handed over to the electronics repair shop to see what damaged had been caused and the unit worked (ac controls, rear demister etc) bar the lights behind the lcd. i would assume that the diode was only to control lighting and didnt harm anything else i got the unit back from the electronics repair shop and all is well (to a point). The lights are back on and ac controls are working. im still paranoid as i beleive the repairer just put in any zener diode he could find and admitted asking chatgpt if its compatible   i do however have another issue... sometimes when i turn the ignition on, the climate control unit now goes through a diagnostics procedure which normally occurs when you disconnect and reconnect but this may be due to the below   to top everything off, and feel free to shoot me as im just about to do it myself anyway, while i was checking the newly repaired board by plugging in the climate control unit bare without the housing, i believe i may have shorted it on the headunit surround. Climate control unit still works but now the keyless entry doesnt work along with the dome light not turning on when you open the door. to add to this tricky situation, when you start the car and remove the key ( i have a turbo timer so car remains on) the keyless entry works. the dome light also works when you switch to the on position. fuses were checked and all ok ive deduced that the short somehow has messed with the smart entry control module as that is what controls the keyless entry and dome light on door opening   you guys wouldnt happen to have any experience with that topic lmao... im only laughing as its all i can do right now my self diagnosed adhd always gets me in a situation as i have no patience and want to get everything done in shortest amount of time as possible often ignoring crucial steps such as disconnecting battery when stuffing around with electronics or even placing a simple rag over the metallic headunit surround when placing a live pcb board on top of it   FML
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
