:stupid:
124mph is what a full weight (1700kg+) R33 GTR will do with 330-350rwkw.
No way it was 500rwhp in a lighter body with 124mph
in america a dynojet the old one s like ours is standed...
if you run a dynodyamic like most of you guys it s not reliable (dyno will not read the same from shop to shop cause its adjustable)
and a dynopack is a hub dyno so it would read alot higher( also adjustable so its no consistance)
  • Replies 121
Who cares what the power really is. The dyno is there for tuning and upgrade comparisons, so long as you are using the same dyno everytime then you can see what changes net the best results. Most dynos in this country are probably dyno dynamics (though I could be wrong, not really sure) and they wouldnt be out by too much more then say 5-10% from eachother. Which in the grand scheme of things isnt really that much.
I can comment on the methanol helping make power safely and easily. It is amazing stuff, you can be around 15% too rich and it doesnt affect power production, it just runs alot cooler, if you run it too lean, it wont knock, it just usually melts pistons pretty quick.
We pumped out 590rwhp on the rb30det w/gt35r last week. Boost bled from 23psi down to 19psi (running on gate pressure only, no controller). When we setup the solenoid and get it to flatline boost to redline I suspect the power will grow a little over the 600rwhp mark. Which is going out of the realm of regular gt35r territory by a long shot.
I dont know why alot of other people dont run it, or atleast run it in a mix w/ 98pulp. I just cant express enough how magical it is. The only negative is you need a smaller less efficient radiator and oil cooler. Not very often you go backwards when running a turbo car in those two areas lol.
there are heaps of people here that are making that power on stock rb25's
why are you not capable of understanding this?
did you look at the dyno thread like we told you?
also a dynapac hub dyno can read higher, or it can read the same as a dyno dynamics etc, as there is a correction mode for this.
(also my previous motor lasted 3 very hard years at that level, but did die eventually)
Ye. They can last at over 400 for a while. But look at his many have broken at 300hp. Any number of things can go wrong
90% is bad tuning, or something breaking to cause the tune to go out, afm/fuel pump/injectors failing. If any of this goes at any power level it can kill a motor quite quickly.
My cousins bf ran his r33 with around 420rwhp on a stock internal rb25 for around a 1.5 yrs thrashing it at drift days before it blew. That was pretty good considering it did alot of street racing and skids also.
mmm..but if youre only running in the mid 120s then it isnt really making 500+ now is it
Exactly as we were saying :D
His "500rwhp" is like our 400rwhp - or there abouts.
So yes - in his terms 500rwhp is most certainly possible
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
