Hey guys,
I have just bought a donor car for my little pulsar daily
It has the same 1.8l engine as my current one and all i need to do it transfer the donor engine into my current daily
As i have never done an engine swap before im not really sure on what i need to do, i am mechanical minded, i just need some advice on what i really need to take out of the orignal car and what needs to be taken out of the donor car to do this. If any of you need more info/specs on the both of the cars just say so.
My original car:
Car: 1990 Nissan N13 Pulsar GX
Engine: 18LE (replacing due to head is gone)
Also might mention that this one is a sedan
The donor car:
1990 Nissan Pulsar Hatch (cant remember what model)
Engine: 18LE (Completely Rebuilt by HM Gem in Dandenong)
Dont know what else to tell you all
Thanks in advance
Dont know who else to ask, and you guys are always ever so helpful :P
Cheers matt
https://www.sau.com.au/forums/topic/346131-nissan-pulsar/
Seems pretty straightforward unless the gearbox/loom is different...
Just disconnect all wiring, hoses, cables and linkages leading to the engine block (driveshafts out should make it easier too). Do this with donor and receiving car. Engine crane will be great when undoing the engine mounts - some cars (usually front wheel drives) are easier to drop the engine out through the bottom of, onto a trolley, rather than lift the engine out of the bay. Recommend leaving the gearbox attached to the engine and bolting it onto the new one outside of the car.
If your head is gone though, you could just pull the head off the donor engine, get it machined and install on old block?
These are the Astra/Pulsars yeah? Should have dropped a C20XE in there :P
https://www.sau.com.au/forums/topic/346131-nissan-pulsar/#findComment-5574346
as birds said, it will be pretty straight forward. you are using the same motor each way so all the plugs, etc should be the same. just unplug everything (label them if you are worried about forgetting what goes where), then drop the motor and bolt it into the other one. you won't need to go swapping ecu harnesses or anything like that. also as birds said, it is easier to leave the gearbox attached. not sure on these motors but i know some fwd motors you have to actually take the gearbox apart to remove it. they don't just pull off in 1 piece like a rwd gearbox does.
if your car has air con then unbolt the compressor from the motor and try to tuck it to the side as far out of the way as possible to save you having to remove it and have to get the system regassed.
https://www.sau.com.au/forums/topic/346131-nissan-pulsar/#findComment-5574713
sorry to hijack this thread. maybe a stupid question..anyways is it possible to a dump a rb25det engine on a pulsar?
Cost way too much to do it...
CA18det best bet. Absolute piss to do and still make decent power for next to nothing ($$$)
https://www.sau.com.au/forums/topic/346131-nissan-pulsar/#findComment-5576565
    • How dare you sell your unreliable Skyline and buy a reliable, Toyota/Yamaha car with a strong gearbox, torsen LSD and Toyota reliability. At least you won't need to worry about oil pumps, big catch can, oil restrictors, blowing off power steering belts, sheering off 3rd gear, failing ABS relays/pumps, etc.
