interesting. what compounds do they have?
Im going to order a set and try them out early next year. Ive got a direct contact to Top Racing but the are f**king expensive - maybe Yoko Australia can get them soon?
As far as i can see these are the slicks that the Nismo GTR RC car and the Club Spec edition are using in Japan.
Bet you they have been specifically developed for the GTR because i dont think there is any other cars out there running 20 inch slicks
They will be pretty good i recon...
https://www.sau.com.au/forums/topic/346153-20-inch-slicks/#findComment-5574916
who knows, they may be no better or worse, then again, there are no comparisons i could find. If you are serious about getting the best track times though tyres are very important and these might be worth a look especially if they were specifically developed for the R35.
also, for those that are concerned about brake clearance/cooling etc or want to use 20 inch wheels, there is at least a slick option now.
https://www.sau.com.au/forums/topic/346153-20-inch-slicks/#findComment-5575365
actually I dont even have a set of wheels suitable at present in 20inch, so wasnt thinking of this for myself, more posting for others interest as I know if I hadnt gone down the pathway of buying 18 inch wheels I would have certainly considered it.
reading an article last night on which slick sizes I should run, michelin point out the following:
A SPECIAL NOTE ON PORSCHE
Compared to the 27/65-18, the taller size offers several advantages:
1. The increased diameter of the tread band permits easier conformation of the tire to the flat road
surface; the tire's tread “maps” to the road surface more readily. This results in improved temperature distribution and increased performance over a longer duration.
2. The greater diameter also increases the total amount of tread rubber available to transfer
power to the ground, again improving temperature distribution and prolonging performance consistency.
3. The taller sidewall helps cushion the shock of power application, providing more progressive corner exit with less wheelspin during aggressive acceleration.
I dont know enough about tyres to know if this is just marketing BS but has got me researching things more.
the 31/71 - 18 tyres I received second hand were only available in the S7 compound which from all accounts is the worst compund to buy second hand. does anyone have the full list of michelin slicks and compounds available? the internet turns up only a limited list which is posted on the european technique website and one or two other places glabally but no where have I found a list of available sizes which is all inclusive of this larger diameter and sizes/compounds. I assume the 71 diameter comes in S7-S9.
BTW Duncan, what is the N1 relative to the slicks I have been using? does it still come in the same compounds or is it a different entity alltogether?
Edited by handbrake
https://www.sau.com.au/forums/topic/346153-20-inch-slicks/#findComment-5575717
I am led to believe the N1's are their own compound, which is roughly equivilent to S8 but (i am told) a much stiffer sidewall.
- We had to use 200psi to get them to pop the bead when fitting them!
I found them the best tyre thus far. And yes the S7's are basically crap after one day.
Dunno how 20" slicks would go, would love to know. I think Miles used some 19" slicks at Bathurst, with paul using 18's? So a comparison from those guys wouldnt go astray, especially the gearing aspect down conrod... Miles, Paul?
I guess one thing to consider is how long a porsche cup race is vs a sprint session?
The tyres are probably constructed to perform best for typical race duration.
https://www.sau.com.au/forums/topic/346153-20-inch-slicks/#findComment-5576062
yes, hard to compare time attack format usage with more longer door to door racing formats.
according to Trevor just now, the N1's are a 9 compound.
s9 hey? (not what he told me!). Anyway i reckon the n1's were awesome, great tyre. It just seems to work better than the others. Perhaps it's the sidewall, i dunno.
https://www.sau.com.au/forums/topic/346153-20-inch-slicks/#findComment-5576619
fellas the 19s were awesome, i loved them. hard to draw a conclusion between Paul and I because my car was set up a lot better and I also had a lot more seat time over the 5 days Vs Paul only about 3 days. By end of the Sprint i was about 5 sec's quicker than Paul. But ive got no doubt he can do the same times as me when his new car is set up better.
Sure the 18's have more sidewall but my 19s were a little wider i think.
Ive got some video which shows me pulling 299 down the straight and Pauls car on 18's was pulling virtually the same numbers. Really came down to who had the better setup... I was flat till last sec and after backing off and pulling 5th was getting into the chase at 260 showing on speedo.
When i pulled 5th into the chase the engine was working hard touching the rev limiter most of the time so im guessing that if anyting the actual speed was 10-20kmph lower if you know what i mean.
Honestly i dont think we will see much difference between 18s and 19s.
But Dunc we will get some good comparisons at EC in the new year... i'm aiming for a 1.38...
Im sure the Japs have done the testing with 20 inch slicks and if they are using them there must be advantages.... anyway we'll find out soon.
Edited by White 35
https://www.sau.com.au/forums/topic/346153-20-inch-slicks/#findComment-5576862
P.S. have you had a close look at how much wider the 20 inch slicks are Vs your 18's...
There is a Big difference.
If that sidewall on those yokohamas is Stiff - then for sure this is going to be the best option.
Remember we are not really racing on these tyres so all that stuff below may not be that appropriate for our 4-5 lap sprints.
Then again maybe im way off????
https://www.sau.com.au/forums/topic/346153-20-inch-slicks/#findComment-5576871
Can't wait to see the video!
and i will be disappointed with anything worse than a 38! 36's or bust.
https://www.sau.com.au/forums/topic/346153-20-inch-slicks/#findComment-5576888
Just watched my video footage of the 2.21 lap at bathurst and at 299 on the speedo on 19inch slicks in 6th the rev shift lights are on.
So Dunc im very close to hitting limiter in 6th.
Speedo has to be reasonably accurate i think.
Insane.
yet awesome.
Edited by LSX-438
https://www.sau.com.au/forums/topic/346153-20-inch-slicks/#findComment-5576910
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
