Finally cashed in my Xmas present today at Calder. I had a drive in a V8 Supercar. Wow! First we had a couple of sighting laps in some piece of shit Ford then I had two 10 min. sessions followed by a driver showing me how fast he actually does it. Those drivers are unbeleivable. Down the back straight I started braking at about the 70-80 metre mark but when an actual driver did it he started to brake well after the 50 metre mark. I just dont know how they can stop a car in that distance. Finished off the day with a barbie. Sensational.
Alan
https://www.sau.com.au/forums/topic/34726-calder-park/
To answer both your questions I'll try to download a couple of pics.If it doesn't work send me instructions on how to do it James. (refer back to the "which school did you attend" thread and me being the dumbest prick on here)
Alan
PS I reckon I worked out how to do it but the picture is too f***in big.
The picture is 492 kb but I can only download 109 kb (or something like that) and I'm f***ed if I can workout how to resize the c*** of a thing :)
https://www.sau.com.au/forums/topic/34726-calder-park/#findComment-695015
I've done this too!
Isn't it a buzz!
The car is a VX SS Commdore with all things racing, apart from the dash and the off tap engine. Big arse brakes, Big arse suspension and all the fruit.
I've also driven the Formula Ford cars with "UdriveVic" and that's even better!!
Glad you had a ball.
BASS OUT
https://www.sau.com.au/forums/topic/34726-calder-park/#findComment-695049
I've done this too!
Isn't it a buzz!
BASS OUT
So its not a 100% V8 Supercar?
What hp is the SS putting out?
https://www.sau.com.au/forums/topic/34726-calder-park/#findComment-696324
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
