Hey guys,
Time to sell the beast.
Item Summary: r32 gtr skyline with new rb30dett motor
Condition: Used (Motor new as of 11/10/2010)
Reason for Selling: Can't drive it
Asking Price: $20000
Delivery Methods: PickUp
Contact Info: PM me
Extra Information:
Here are some details:
History: Car was imported from Japan with 98,000k's on the clock by a young guy who had it for 6 months, I then bought the car off this person and have owned it ever since. During this time I have probably put around 6000k's on the body (yes that's all). It has been off the road garaged for what seems like an eternity. I removed the rb26 motor out and decided to do a rb30dett motor instead which resulted in the vehicle having the below mods.
I have spent in excess of $25,000 on the car on top of it's initial purchase price. Obviously I don't expect anywhere near that back, but the purchase price of the car would however be nice
Mods below:
1990 r32 GTR Gunmetal Grey (Imported 2004 been on the road only a handful of times, was always being worked on)
Body has 113,00k's
rb30dett motor (Has about 150k's on it, so basically new build, still being run in as of 07/10/2010)
Wiseco 11cc dome top pistons
Eagle forged H beam rods
Nismo rod and main bearings
Ground crankshaft with grub screws and welded and machined long oil drive
Fully balanced rotating assy
Block Acid dipped, decked 0.8mm, all new welsh plugs, return oil galleries modified
1.5mm Tomei oil restrictor front, rear blocked
4WD Adapter plate (Early pro-engines type)
r34 gtr sump and front diff with new seals
Tomei MLS HG
HKS/Tomei inlet/exhaust cams gears
Fully recod rb26dett cylinder head, all new valve stem seals, valves seated, etc.
700cc blitz injectors
Bosch Intank 023 fuel Pump (800hp pump)
Hicas Lines modified to take fuel (Increased flow to front of car)
Rear HICAS removed with TOMEI lock bar (Now uses a rb20det power steering pump with no HICAS)
Genuine Nismo turbo's rebuilt by MTQ old as motor so new (60 front .64 rear)
HKS 2.5 Split pulse dump pipes
2.5" from each turbo to 3.5" main to hi-flow cat to Magnaflow muffler with 3.5" outlet (Exhaust cost a shitload but looks and sounds great)
N1 oil pump
New rear main seal
Custom pick-up with modified oil pump housing
New rb30dett timing belt and genuine Nissan idler/tensioner
Triple core Aluminium radiator
New header tank
K&N super flow pod filters
Splitfire coil packs
Apexi Power-FC ECU with Hand controller
70MM Justjap Front mount intercooler
Blitz Spec-R Dual solenoid boost controller
AEM Wideband AFR gauge with proper wideband bosch sensor (Had bung welded in for it)
Defi style oil pressure and boost controller gauges (Do the needle start up like defi and go back to a digital controller)
Veilside 340km/h cluster
FET turbo timer
New Nissan centre air vent
HKS Kansai Torque split controller (Rare and exy to buy)
Ogura twin plate clutch with new plates (Rebuilt with new plates with motor so a new clutch basically)
ATMO vent catch can setup
Nismo big bore clutch master
Nismo braided clutch line
Nismo braided brake lines
Nismo front castor rods
Nismo Adjustable fuel pressure reg
New genuine Nissan fuel filter
r33 gtr v-spec big bore brake master cylinder
Whiteline upper camber arms with new bushes
Bilstein height adjustable coil overs
New sway bar bushes
New battery
New windscreen
18x10 Termist deep dish wheels
BRAND NEW FALKEN 285/35 TYRES ALL ROUND LAST WEEK COST $1600
Tomei Oil sump Baffles
Remote Oil Filter Locator
30 Row Oil Cooler
In Dash DVD Player (Double Din with touch screen)
Nismo short shifter
Nismo racing peddles
Momo old school racing steering wheel in excellent condition
Made 270awkw at just 14psi on a very safe tune and with the 3ltr block comes on hard. Has plenty left in it but was not pushed as motor is still fresh, have been told 300rwkw should be easily done once another more aggressive tune is completed, all supporting mods for in excess of 300rwkw are all there. Can talk to tuner to confirm and have dyno sheet. To look tip top car needs skirts put on, and front bonnett/bar painted in gunmetal, I just don't have time with work and have spent enough time/money on it. The rest of the hard work has been done, and trust me it was not easy.
Comes with genuine gunmetal factory skirts ready to go on. Just put 6 months rego on recently.
Location is Brisbane 4118, message me if you wish to view it.
Edited by James_03
https://www.sau.com.au/forums/topic/347477-r32-gtr-with-built-rb30dett/
  • 4 weeks later...
  • 6 months later...
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
