the way i worked it out was its probably revving to about 7000, maybe a bit less like most ppl do...
the graph doesnt show RPM but it does show rod speed.. so if 180kmh is close to 7000, 90kmh is close to 3500.
its a few rpm off but close enough, boost is definitely well and truly on before 4000. a good achievement.
no way 3500 is 90km :no:
Anyway out of curiosity and boredom I just laid my dyno sheet next to battery's..
Im sure many of you have done this already.. but im posting it.. :D
Not alot in it really, they are running almost identical boost , I have a fair bit more midrange torque and an extra 20kws at 5k, but nose over after 6k where they are both pulling 300kws,
Then he keeps pulling past 7 and smashes me..
Just remembering though I have alot less mods under the bonnet <<read excuse for losing... :Pbatterydynosheet.jpgtune300.jpg
Im not gunna bother comparing anything to Simons freak of nature....
well know how many revs it is if we know where the run ends.. speed and RPM are always relative. you will do double the speed at double the revs in the same gear etc.
nice comparo too :) i cant wait to pop a 20G on my SR
Aaww don't be sad Simon you know your my hero.
Its more the fact I can't be bothered converting all your dynosheet figures to something legible. :laugh:
I think u were making the same as me at 5Ooorpm
On low boost mine is about the same as yours at 5000rpm, high boost close to 30kw more
You guys need to screw more boost in... 2bar or bust :)
Edited by SimonR32
Yeah you can see my 20g making more on the green line but that was 21.5 psi which is 4psi more than the blue line and the gains were insignificant..As Roy said the little comp just can't push any harder ,its giving all she can give..especially on my setup..If I get a better manifold and plazmaman plenum and better cooler it could possibly push for a little more.. But looking at the comparison I would sooner just get a T67 than push this any further.
Not sure why battery didn't push more in..
Got a scanner Artz? I think I could use my broken ass Photoshop skills to overlay onto the same image..
Just re did all my cooler piping in 2.5"(was a mix of 2.25/2.5" before) and now i'm thinking maybe I should move to a bigger Throttle body, not sure if there is much point cause the stock one is still bigger than the 2.5" piping ??
Haha I was putting mine over a picture of yours on the computer, I was gunna trace it but gave up..its almost identical though with yours just dipping a Little between 4-6rpm
That's the same size as my cooler piping I guess there is hope for it yet :D
Got my T67 today and have a few questions.
It came with a 4" Anti surge compressor housing which i did not want i wanted a standard 4" Compressor housing. Will this matter that much?
What is the best way to block the water lines? The shorter of the 2 (Water return??) I was simply going to find a bolt wth the same pattern but shorter and bolt it in nice and tight with a coper washer.
Not sure what to do with the one that goes around the back of the block should i just cut it off shorter and fix a blocked off bit of hose on the other side? Or blank it off at the source, which im guessing is under the plenum?
Any help is appriciated keen to get her back together, tonight i have connected oil feed(One supplied with the turbo is a bit long) and return. Finished replacing exhaust manifold studds.
Also I have one of those NZ manifolds and i am not happy with the way the wastegate pipe comes out it is really really close to the body and air con lines.
Should i modify this pipe or just blank it off and run the gate off the turbin housing?
is this one of the mild steel ones from ebay? i was pretty keen to get one of these for my rb20 anymore negatives?
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
    • Yes they do. For some maybe. But for those used the most by abusers, ie Skylines, the numbers are known. The stock eyebrow height for R32/3 Skylines is about 365/375mm or thereabouts. The minimum such heights are recorded in adjacent columns in the database.
