steps to upload a pic that is not currently on a web page ie. on your computer
1. Go to Add reply/full editor down the bottom of the page
2. Underneath the text area where you can type something there is a button called "Click to attach files" - click that
3. A window will appear, select the file you want to upload to the sau server, it will upload with a progress bar on the right.
4. you will see the bar disappears and on the left it has a small preview icon of the item and on the right side of the window it says add to post... click in the text area where you would like it then click "add to post"
5. It will come up with something like : attachment=blah blah... that means that file will be attached.. post and your done...
If this doesn't work perhaps update your browser or get the latest firefox...
Photobucket is another good example, you make an account, you upload your images there instead of directly through sau, then add the link into the sau post and your in business
here is an example of using sau's uploader:
  • Like 1
https://www.sau.com.au/forums/topic/347916-fcuk-this-forum/#findComment-5596779
Was excited about my new upgrade plans courtesy of my wife i thought i would post my old dyno sheet and new plans but this new format says there is no files to be uploaded even though i have done so.really pissing me off.
Its the same as the old version to upload photo's, and it works fine.
It's the user, not the forum :)
https://www.sau.com.au/forums/topic/347916-fcuk-this-forum/#findComment-5597082
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
    • Hi, i’m converted my r34 4dr auto to manual but need help with gearbox wiring. There are bunch of wires no idea which one for speedo drive, neutral, reverse can anyone help me. IMG_6860.mov
    • Also this is my garage ornament 😁
    • @TurboTapin hey man thank you for all the info! I am about to order my cd00a today for a rb25 neo s15 build I am currently trying to get the ball rolling again on 😁 what is wrong with the Collin’s adapter? Is the bellhousing machining 15mm because that’s how thick the Collin’s adapter is or is that universal across any I decide to go with? Also do you recommend any adapter in particular? Thanks man 😃
