is there any way to check the oil seals in the turbo without pulling it appart?
i have had issues in the past where the oil drain had a 5/8" T piece in it (which has since been replaced with a 3/4") to allow the VCT oil drain to enter the sump. however the oil wouldnt drain away fast enough which caused the oil to backup into the turbo and force its way past the seals.
if you pull the dump pipe and intake off you should be able to tell if its the turbo or not,
i rebuilt a mates diesel hilux 3 months ago because it was using 1 litre of oil in 400k's. didnt blow excessive blue smoke but had a tinge to it.
when i was pulling it down i found cyl 1 oil control ring was seized shut, other than that the motor was fine.
who assembled your motor?
Well one of my -5's leaked oil through the exhaust seals during it's installation, I could see it coming out of the dump pipe before I attached my front pipe up. Called GCG and they said it's normal and it'd seal up over time. I'm very vague on the actual numbers but when you go over a certain amount of oil pressure (30something psi?) you need restrictors. They wouldn't help you in your case if your drains aren't big enough, but I do remember also reading about oil consumptions and one of the first things they say is check the drains for fast and proper drainage. I'd assume blocking PCV system would give you the same effect. Too much oil/crank pressure.
proengines did the final assembly and that was over a year ago, these problems have only started in the last couple of months.
That is a good point, an incorrectly set up catch can system that pressurises the crank case will cause oil consumption issues.
the catch can vents to atmo and the 1 way PCV valve is connected and functioning as it would from the factory.
The turbo (3582R) has a built in restrictor, there is however also an aditional restrictor before the turbo as that was thought to be causing the oil to push past the seals (this issue has been fixed the whole drain from the turbo to block is 3/4")
do a fairly agressive leak down test on it (@ operating temp), it will tell you whats going on.
Here's one we did not long ago.
CYL COMP LEAK DOWN
1 155 10-16% @100-110psi
2 155 10-16% @100-110psi
3 155 10-16% @100-110psi
4 155 10-16% @100-110psi
5 155 10-16% @100-110psi
6 155 10-16% @100-110psi
http://www.carcraft....ster/index.html
finally got the leakdown test done.
Compression 150-160 on all cyls
Leak down ~25% on all cyls @ ~100psi
from the earlier test that suggested almost all the lost pressure was going past the rings and that leak down figure i take it the rings are gone? :(
tunes ok and very conservative at load.
if i had to put it down to anything i would probably put it down to machining tolerances possibly being a bit on the loose side (as its always been noisy) and that during initial tuning and run in it had to be run fairly rich to idle smoothly as the injectors were partially blocked.
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
