Hey
I'm contemplating to upgrade the turbo on my car but my mate was telling me my r33 non-turbo gearbox wont be able to take the extra power. I've tried searching for power figures but nothing is on the net regarding the max power for a n/a gearbox. Anyone on here know that answer? Would it be a better option to sell my current box before destroying it and swapping it with a turbo one?
Cheers
https://www.sau.com.au/forums/topic/347992-r33-na-gearbox-power/
they arent the same.
pretty sure rb25de box is the same as rb20det. they are the same size and i noticed this when i was working on Dom's car.
rb25det gearbox is much larger
Edited by DamageInc
Serious so their the same? no... they are weaker.
So i wouldn't have to watch out for the power gains? replace it with a custom GTR box from Japanese Motor Sport (same internals just customized to be RWD)
cheers steve
yea i remember you telling me that mitch
do you reckon its worth me getting them changed over??
cheers mitch
what turbo you wanting to upgrade to?
remember you'll need to upgrade the ECU aswell if its not a stock rb25 turbo and you may need a boost controller depending what you go for
I was thinking of upgrading to a garrett 3540r?
or i was going to get my turbo highflowed! Whats the going rate at the moment to get them highflowed?
how much you reckon that gtr gearbox will set me back?
cheers mitch appreciate it
+1 The Na box is smaller than the turbo one. I have done all these conversions about 2 yrs before you like turbo, brakes 5 stud conversion. I know one thing the Na box didnt last long. I now have a turbo box which needed different tail shaft and the plugs were different. Clutch and flywheel are same. But havent broken one since and now have 260rwkw
could go a 3540r , remembering you'll need braided lines , custom dump pipe and a new front pipe.
not to mention an rb20/z32 ecu or a power fc. and you would probably want to do bigger injectors and a nismo Fuel Pressure Regulator.
i think a hiflow through ATS is about $2400 and thats using 3076r internals so it looks all standard from the outside and will pass regency.
just source a standard 25 box people will try to charge more the "RB26" box converted to rwd
no they wont
NA box is rb20 gearbox.
Turbo box is... turbo box
GTR box is rb25 turbo box with transfer case to make it awd
GTR box with transfer removed is a cheap rb25 box. (will need different coupling for tail shaft)
GTR/gts4/rs4 gearbox = $800(avg), to convert to rwd $150 - 200
rb25det box = $1500 (avg)
you do the math.
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
