Hi,
I have recently fitted a Turboetech Boost controller to my car, and after winding the boost up to 9 PSI, the car now has a bad flatspot on acceleration between 4000 and 6000RPM, after 6000 it Revs past it, and seems to be fine. Between 4-6, its not like its missing, but just generally lacking power, like it can't breathe or something - but will rev past it in all gears.
Initally when I installed it, the car started missing badly, so I gapped the plugs to 0.8MM, and siliconed up the coils. The missing got a lot better, but I thought the flatspot was the same problem. I ordered and fitted spkitfire coils today, but the car still has the flatspot. It seems to mainly be when the car makes full boost - after 6000RPM it tapers off to about 8.5PSI and the fault seems to clear and car accelerates better - can feel the shove after 6000 - not sure if boost tapering is just a coincidence....
I have also tried an ECU reset, and have driven the car while watching readouts in OBD Scantech, nothing really stoodout as being massively wrong. There were no faults logged either. Also had quick check for boost leaks, none visible.
A couple of things I have seen on forums is checking ignition timing, or possible turbo breathing issues. I would have thought at this boost turbo would not be an issue. As for ignition timing - what should it be? Can probably check timing tomorrow arvo.
Anyone have any suggestions, or similar issues that have been resolved? Let me know if any more info is needed..I took a log using OBD Scantech, from about 2500RPM in third all the way to redline, as per zip file below Boost was max 9.2 PSI in this run
Thanks, Russel
Full list of mods/history
Car is 1993 series 1 R33 GTST
FMIC
Splitfire Coils
GFB StealthFX BOV
Cat-back 3in Exhaust
New plugs/fuel filter/all fluids
test run, third gear.zip
https://www.sau.com.au/forums/topic/348144-flat-spot-4-6000rpm/
ECU, if standard may be the problem. TBH a good dyno print out could help, along with a good tuner to help diagnose the problem. May cost dollars but who cares, or wait for more people to comment! Come on mad082, I know your lurking some where!
EDIT: BOV may also be a problem, how was it before BOV?
Edited by Shazza24
Just watched the log file, had only seen live....it appears R&R is spot on, at about 4200RPM it drops timing back to 12 deg, at almost exactly 6000RPM it goes straight to 20deg, and works up to about 25 or so after that. So painful that its doing it at such low boost :(
Thanks for the help.
Edited by Pope
    • Hi GTSBoy, Excuse my ignorance but what does a "Bad" Knee point mean ?
    • HFM BM57 has a "bad" knee point, IIRC. It's not the same thing as the later R chassis MC.
    • The ATTESSA is functionally identical to R34; there were a bunch of JDM models that continued ATTESSA including Fuga/Q70, Skyline/Q50, Cima etc as an option. All with Auto only and I think mostly for snow regions. AFAIK there were no AWD VR30DDTT sold in Australia - it is on my to do list to check regs for racing a LHD car in Targa/ATR/AASA/CAMS events because if I can get the auto to work it would be interesting to run a 4wd car The Ecuteck TCM tuning is the same model as their ECU tuning, they already have it for R35 and Dose's favourite, BMW. You buy "points" to allow your computer to be tuned, buy either a bluetooth (phone app) or bluetooth+USB+Key (phone and PC) dongle, and pay for a tune that will be locked to your tuner ( ). You can also access the tuning software yourself but 1. it is mega expensive and 2. these computers have a billion parameters that intersect, so how could you ever spend enough time on it to get a decent result.
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
