hey all
just got defected for usual stuff wheels, too low, two air mods.
the copper said how many times you been done before so i said a couple and hes like your obviously not learning so hes sending me to Denmark St Kew which i assume is a vicroads office and i have to clear it by special appointment with "Ange Curic" the "head mechanic" there..
anyone else had to do this before?
vicpol > my life
cheers for any help
Kyle
https://www.sau.com.au/forums/topic/348528-just-got-defected/
well the copper seems to think that sending you to get your car fully checked over by the head mechanic they are going to find alot more defects on your car.as to him you are not learning your lesson for being defected. have fun with this ps take some lube with you. :) lol
Vic roads hate the police and defects
From what i been told buy head guys there the police send things to them that just wastes there time
and at a vic roads you can go to any vic roads you want to clear your defect
Sounds pretty accurate to me.
i was as nice as i could possibly be but he was just being an asshole, i was driving normally coz i had my sis in the car so wasnt doing anything wrong, i got pulled over again on the way home as well haha :(
Sorry guys, bit off the topic, but my brother got done for similar mods, but he copped a $299 fine? he got done for minor defect (too low), no rwc required but copped the fine? and 299 mind you...Anyone copped a 299 before? i though they are 180 or somthing, not 300.
it has been done before...not sure for minor tho. maybe the cop was having a bad day.
yeh that sucks man, good luck let us know how it goes..
the $300 is basically standard with every defect now i think its $292 to be exact unroadworthy vehicle, like its not expensive enough turning car to stock and shit fkn kents.
die vic police. ina fire preferably.
i just googled kew vicroads and found this:
Note: The following two offices are administrative offices only and do not conduct registration and licensing transactions.
Eastern Regional Office
120 Kay Street
Traralgon, Victoria 3844
Kew Head Office
60 Denmark Street
Kew, Victoria 3101
what is this magical place eeek
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
