I have NO idea what is causing this sound. I made a thread about it a while ago on my old car about a weird squeel at certain rpm. My new car didn't do it..... Until I swapped off the atmo BOV for the standard nissan BOV the f**king sound came back! Its like a EEEEEEEEEEEEEEEEEEEEEEEEEEEEE sound which will just maintain it self if I can locate the RPM its produced at. So what I mean, if the sound occurs at 2000rpm, the sound will finish as soon as I get to 2100 rpm. but if I hold 2000rpm it will keep going until i let go or go a little faster.
What the hell is it? Is it a failing BOV? Is it a leak?
https://www.sau.com.au/forums/topic/348947-bov-sound/
Unlikely to be the BOV. The BOV would only fail at a certain pressure if it were faulty, not an RPM. Because of this, you would be able to replicate the sound at a certain throttle point for any given RPM (not guaranteed).
I'd be thinking check your belts.
Does it make the sound at 2000rpm when the car isn't moving in neutral? If so, pop the bonnet and rev the engine by manually opening the throttle body with your hand. Find the point where it makes the sound, and try to work out where it's coming from.
https://www.sau.com.au/forums/topic/348947-bov-sound/#findComment-5608119
Only when in gear and only if I hold certain pressure. If I'm rolling down a hill a 2krpm it wont make the sound, but if I pushing up a hill at 2krpm it will make the sound. It is only if there is pressure. If I remove the BOV and fit my atmo BOV back on, the sound is gone. It made exactly the same sound in a completely different car(the exact same BOV).
https://www.sau.com.au/forums/topic/348947-bov-sound/#findComment-5608227
^ if blocking it doesnt get rid of the sound, also take a a look at the gaskets and studs around the exhaust manifold and turbo area. I had a couple of broken studs and a chunk of exh manifold gasket missing. Made a real high pitched squeal all the way to redline when on boost. drove me fkn insane...
https://www.sau.com.au/forums/topic/348947-bov-sound/#findComment-5608967
    • Not sure the US can import anything other than the C34 Stagea's, but if you can and you need to to tow, DO NOT under any circumstances get an M35 Stagea. If it is just as a family car and your country/state allows it, absolutely and definitely get an M35 (3.5L if possible as it is effectively a 350Z) over a C34.
    • Punch your VIN (nm35-xxxxxx) into Amayama.com You can see everything there quite easily.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
