Have wanted to give macro stuff a go for a while, may buy some extension tubes and give it a go on the cheap with my current lenses.
Heres a few from the other day for now though:
Thoughts and comments welcome :)
Also, if anyone knows how to deal with very bright reflective bits (first photo) when using flash let me know :)
Tried lowering your flash exposure comp on your camera?
I put mine on -2 to avoid the exact thing youre talking about when taking pictures.
If I lower the flash to much it wont show the car properly, Its a highly reflective strip. Numberplates are also a problem for that mater...
Both the flash and exposure as set manualy also so no use for exposure comp there.
Maybe a small dome difuser on the flash might help?
Serg,
The only way to compete with reflective things and flash is to bounce it. Although i assume that wouldn't be appropriate as you would lose too much flash power at basically night time. i.e. flash bounces and spreads from above, otherwise it will always reflect :( Try diffusing it with a tiny softbox.
Edited by FST513
Serg,
Dont realy have anything to bounce it off, even if I did have Enough flash power. Will try a small softbox when I find some $ for it and see how I go there
rear 45 and sun roof shots are by far the best. gay shadows kill the other interior shots, the exteriors are bit dark. good shooting though
Went for the Putty rd cruise here today. took a couple shots. Here they are. I avoided the camera for a change. it was nice to just drive and chill out for a change :)
The run
The line up
The cube
Dodgey Pano
Yeah I noticed that headrest shadow afterwards... Kinda fkd the whole thing.
Use cactus triggers... Have a spare set if ya need one
I do need a set, but dont have much of a cashflow at the moment. lol.
As for headrest shadow, ive done it before. Easiest way I can think of to avoid it is to drop all the seats back as low as possible and out of the way. Well, that or use more flashes?
Edited by Jay019
Nice car shots in here. Need to learn from you guys how to take pics of cars.
Here is my attempt.. washed my car for the first time in months so took a quick snap.
Edited by siddr20
Hey just a shot that i took on my weekend away at Yallingup. Was kind of just chilling on the beach. Shot posted as i've taken it. I still havent gotten a new lens cos other stuff keeps coming up.
A new lens would be nice but you don't need one as long as you can still shoot :)
that shot is nice. What i think would have improved it... I probably would have moved to the right a bit so you could see the beach join up, and put more focus on the footprints/waves. nice shot though, relaxing :D
& a level horizon
thats not too bad a shot Sidd, least you have the front wheels turned properly. Nothing worse than seeing car shots where the wheels are pointed at the camera (im guilty of this, lol)
only thing I would have done different is a slightly lower shooting angle... and tell that dog to piss off out of frame :P
heheh thanks jay :) I wanted the dog in there for the added "awwwww's"... hahaha just joking. Yea it was just a point and shoot shot. Got all my camera stuff out of the car, and took a quick snap before I walked to take pics of the groom on a horse :)
- Just a random image below to show you..
I love Indian weddings! Everything about them is so cool!
It's good to see your car clean lol. You should wash it more often, it always looks good in that pearly white colour.
Will post up snaps of the new evo tonight!
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
