For future reference
Some of the info in this thread is not correct (points finger at Terry, nicely)
I run 19x9.5 +12 GTC's Face 2 (BAKES old R34 GTR wheels)
He use to run a 3-5mm spacer to clear the Brembo's
+12 Face 2 are "B" disk. They miss my R34 GTT calipers by 1mm
+11 Face 2 are "A" disk which are for brembo's. Only 1mm different in offset but 5-6mm difference in caliper clearance
You can confirm this reading the Rays wheel charts
The difference in extra calpier clearance on the A disk +11 is done by running a smaller outer rim width (less dish) than the B disk +12.
Sorry Darrin and others if I got A & B mixed up! Dear oh dear, I hope no-one bought GTCs that have spokes crashing into the GTR calipers!!!!
Volk GT-C rims looks good on a BNR34, i've had mine on the car for about 6 years now. still looks good but becareful as the dish scratches really easily.
F**ken HOT !
what size and offset you got there bud ?
Hey all,
im in the same situation as a few of you on here, except i have an r33 gts-t and im in currently trying to figure out what all this offset 'jazz' means, as im currently in the market for some 19in gt-c face 2 rims..
Do the off-sets and other specs differ from a gts-t to a gtr when in comes to clearances and fitments???
What to you recommend for someone in my situation??? please help!!
Also Dumpe, are u selling those te37s once you've got your new treads??
cheers, henson!cheers, henson!
  • 10 months later...
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
    • The downside of this is when you try to track the car, as soon as you hit ABS you get introduced to a unbled system. I want to avoid this. I do not want to bleed/flush/jack up the car twice just to bleed the f**kin car.
    • But again, the engineers said your cast aluminium would be fine based on the load that would be stretching that section. Same load stretching the bolts in a flex (not the twist), with a much smaller cross sectional area than the original part you've broken. It's why you'd need to be using higher strength bolts, but that's just making up for the strength you lose with less area...
