just after a point in the right direction, have searched but not found any 100% answer on this - I wanted to check the ignition timing on my series 2 R33, I have a pretty basic powered timing light. I've read that you can put the inductive clamp on the timing light onto a looped wire that runs off the coil loom near the firewall, with there being no ignition leads on the motor to run it off. There are two looped wires though on mine, one all white, the other black with a white stripe - anyone know which one to use, or have any other handy info on checking/setting the timing? pointers would be appreciated :)
https://www.sau.com.au/forums/topic/349069-how-to-check-ignition-timing-on-r33/
I couldnt get my supercheap timing light to work with the looped wire
what i did was find an old ignition lead, pull the coilpack out of cylinder one, put one end of the lead on the spark plug, stick a bolt in the coilpack (one that fits snug but still makes contact) and then run the other end of the ignition lead to the bolt. Then just run the timing light as normal off the lead
What you have to do to get a correct reading however is pull the TPS plug off (Not sure which one, just pull both I guess) and it should give you the true base timing.
Im not sure what the go is with the looped wire, some people can get it to work others cant. The way I mentioned is the easiest if you cant get the looped wire to work anyway.
oh ok, I didn't know about the pulling the TPS off part.
Yeah my light is just a supercheap job too, hoping it will work on the looped wire but will see. Do you know which looped wire to use? as mentioned, there are 2 on mine. I'll try both I guess, but just trying to narrow it down
pretty sure with disconnecting the TPS you have to have the car warm, turn the car off, unplug the TPS, start the car again, rev to over 2500rpm 3 times in 5 seconds. this put the ecu into base idle/timing mode. once done checking the timing simply turn the car off and plug back in the TPS.
and as 89cal said, the old ignition lead method is the easiest and most reliable way to get the timing light to work properly.
I didnt know that last bit... but then again i did mine with a power fc so might be different.
handy to know but :)
and FYI when I did my base timing, i could notice the timing on the hand controller dropped from 20 to around 14 when i unplugged the TPS (with it running) so i just ran with that. next time i might try doing as you suggest with turning it off, unplugging tps then revving it.
might not need to be done for the PFC.
if you have an ecu with a hand controller you can simply match the timing on the ecu to the timing with the light. it doesn't have to be in base timing mode. same goes for a consult cable and a consult program, however some consult programs also have a base idle/timing mode function in them. which allow you to lock it into that mode without having to unplug the TPS
with my timing light i found that when i clip on the sensor wire it doesnt give a proper reading, i just leave the sensor unclipped and 'hanging' off the loop wire it works fine. bit weird but it works.
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
