The usual story it seems, R34 GTR straight from Japan with Tein coilovers that are too stiff and harsh for our dodgy roads, from what I have been reading the easiest solution is a new set of coilovers with softer springs. The Tein super street Aus spec ones seem to be whats needed but I can't find who sells the Aus spec ones, so could someone point me in the right direction please.
Also would there be any point in trying to sell the stiff Teins for parts etc as they seem to work very well on the good sections of roads except for the left rear one having a squeak whenever the car hits a bump.
https://www.sau.com.au/forums/topic/349315-tein-ss-coilovers/
Found a set of Tein super street coilovers, bought locally but was very tempted to get them from the UK off Ebay. $1032.23 plus postage if you use your old tops, or buy a set of tops for $100 locally.
If the price was just under $1000 I would have got them but didn't want the potential problems of GST Tax etc for being just over the limit.
Edited by thatlbeme
Fulcrum suspension are the only approved distributor for Tein in Australia. They did all the development of the aus spec versions of the super streets.
What type of Tein's are on there at the moment? If they are circuit master RA/RS/RE then you can get them set up for local street conditions.
The only sticker I can see is on one of the rears and I couldn't find any info about them. It says "SPORT SPEC, DRIVING MASTER, type HA"
They must have very good roads in Japan as they are very firm springs.
Do you know if the HA's are monotube or twin tube design? Twin tube will taper at the bottom of the shock body where monotube wont - mono is what you want. The SS are an older twin tube design. Might be worth giving Fulcrum in QLD a quick shout and see if it is worth having your HA's revalved with some softer springs.
How much are you willing to spend?
If I am looking at it right they appear to be monotube, that would be great news if the HA coilovers were able to be revalved. Probably be able to put them on Ebay and sell them "as is" with needing to be revalved.
Its a shame I already ordered the super street ones as rebuilding these would have probably saved me money.
    • Thank you, 100% the intent. New coils were due and the 17" sixers look/feel loads better than the stock wheels. The aero options are so spot on.   Thanks for the warm welcome, all!
    • 98 r34 gtt Been rocking my latest setup and car running like never before. Have put a good 200 miles on it since all the latest changes and additions. everything is dialed in and have been driving it a bunch.   However, all a sudden last weekend as soon as I pushed throttle passed 4k and the engine stumbles, (slow or fast acceleration) hesitates and doesn’t go above 4100 or so, like a misfire. Everything else seems fine. I had a “good” set of coil packs that I removed from car when I first got it when I changed them over to new coils. I swapped out current ones for those, but no change. I also changed the plugs, no change. Seems to rev over 4 when out of gear with no load just fine no “misfire”, but as soon as its in gear with a load of any kind, it “misfires” as soon as rpm drop back below 4 k it runs perfectly, smooth, starts, restarts and drives fine as long as I keep it below 4 k while in gear. All readings look fine, no CEL   Any idea as to what could all a sudden cause an issue when pushing rpms passed 4 k?
    • When you say your cams are 272/262 is that 272in and 262ex?
    • We're arguing semantics. I am saying 45 accel and a 55 deccel ramp are "2 ways". Even a 45 degree ramp and an 89 degree ramp is "2 ways", because it is literally... two ways. The cusco 55/30 ramp is a 2 way. It's two ways. I get it though - in normal nomenclature a "2 way" would be 45/45 or 55/55 or 60/60 i.e the same locking in both directions. And something like 45/65 would be considered "1.5 way". I would then say if we're getting into the nitty gritty then every locking diff is a "2 way" diff and we should not speak in 1.5, or 2 ways but ramp angles instead. Which ofc if one of those ramp angles is 90deg, that side is not doing any locking. :p So Nismo don't obviously sell 3 things. The fact of the matter that they only sell two items really goes to show that there's a 2 way and a "1,5 way" which is really a 1 way. I believe the actual lockup for the 'adjustability' of the GT pro is really just setting preload for when the ramps actually start locking up. It's not changing how much 'wayness' there is. It is (somehow) horribly explained. People just buy whatever diff and go "locks up good bruh" and that's what ends up on socials forever.
