So, first time I drive my car in 3 weeks and I cop a flat on the way home. Good news is it happens close to home and I make it back to HQ before it goes totally flat on me. I've put the space saver on and I'm guessing the rolling diameter will be different to the 18's I've got shod in 265/35 rubber. Any dramas with the 4WD system and the rear diff to consider? Clearly I'll be taking it easy and I'll be getting the puncture repaired tomorrow but......?
Thanks.
p.s. driving to work tomorrow at 06.00 so would appreciate a prompt reply.
https://www.sau.com.au/forums/topic/349857-r32-gtr-spacer-saver-spare/
Thanks Terry. Yeah, kept speeds to 100kms per the instructions. Well, I've done the 40km drive to work and no lights on the dash, but the torque gauge was on a minimum reading of 5 and was much more active than usual. On light throttle applications where more torque was required (e.g. slight incline whilst doing 100) the gauge would dip up and down slightly and there was a slight pulling pushing sensation from the driveline.
So, clearly the OD of the spare was not the same as the rims and it was a little upset. Hopefully I'll get it fixed before the drive home.......
I do have 2 of the space saver spares and I'd be a lier if I said I'd not thought of putting both on the back and seeing what impact that had on the 'handling' of the car in 2wd mode.......
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
