My driver's side window is slower to wind up than the passenger side, but they both go down at the same speed. The "auto" feature on my window does not work on the driver's side, but does work on the passenger side. Also when you close the door and the window moves up a little bit, that does not happen with the drivers side but it does with the passenger side.
Will pulling apart the door trim and cleaning the driver's side motor fix all the issues or would it be smarter to just buy a whole new motor?
It's definitely best to do things properly and in this case, replace the motor as Chris suggested. It's not like Nissan's window motors are built poorly like Ford's. Those things definitely need modification to make them actually reliable, much like what I did to my BA wagon's lock motor/mechanism.
I haven't read all of the posts above, but I thought I'd share my experience: the window motor stopped working too. First it was half working, then completely stopped putting the window down. Went to Nissan who stated I require the whole motor to be completely replaced. They quoted over $1k for the job.
After speaking to an electrician, I was informed that the motor inside just likely needs a bit of cleaning. There are plenty of instructions that can be found online on how to get to the motor. When you disassembly the motor, you may realise that it consists of moving parts that just get worn out and need cleaning for better contact (research a little about how a motor operates if in doubt). After a good clean of the coils etc, it works great so far.
tell that to the customer that just left my shop. he was following this thread and had the drivers motor FAIL in the down position.
forget trying to save them. when they start not going up all the way or falling to half way - replace it.
I wish I had the motor for this car on hand. would have saved him a trip back here.
I know I am living on the edge, but a few weeks ago, mine jammed in the down position and it was a long cold drive from where I was to home. I searched the internet for some clues, and found it was a common problem. I found one post where someone just whacked their door, and it worked, so I gave it a go. It worked. The window went up, and kept working for a few weeks, before it happened again. And another whack, and it was back in action.
This is no permanent fix in my eyes, but if you get caught out, give it a go to get home. And we are not talking too hard, and it was on the outside of the door, I did it from sitting in the drivers seat, with my arm out the door.
Typical of a dealership.
I have yet to come across a motor of any application that only needed a cleaning to last for years upon years. If something gets worn out (not dirty), then cleaning alone is not restoring the motor back to its original condition or even close to it. The best you can hope for are slightly worn brushes but not too far gone. All you've really done is prolonged the cancer patient's life expectancy as opposed to curing it. Not the best analogy but you get my drift.
In the end, it's all well and good if it's your own car because you only have yourself to blame if you find yourself having to fix it again down the track. In Chris' case, he runs a reputable business and it would look pretty bad for him to send away a customer with a cleaned motor only to have it come back again not long after with the same problem. Besides which, why do the same job twice because you took a gamble?
tony,
i think we are trying to re-educate the 'educated'
there is no 'fix' for this . what i have found over the years is a lot of bad information on forums that claim to fix things when they really do nothing.
general rule for a v35, if a door acts up have $1 k per door handy if you cant chnge the bits out yourself.
again there is not a quick fix for this problem..
  • 3 weeks later...
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
