They should juuuust fit, but you'll need to use 15mm or 20mm spacers (from memory)
I have a template for this brake kit that you can print, cut out and put inside your current wheel to see if they will fit... but it is on the home PC. Will post it up tonight.
Here is the direct link to the brake template: Liiiiiiiinnnnk
Yep, that's the one. Thanks!
(no need to turn on the PC tonight then :thumbsup: )
Awesome upgrade Chris, have wanted to do this for just over a year now... just need to get the wheels to fit them first lol
Interested to know though, is there is any brake dust or squealing from the pads?
I ordered them and though 'shit, these better fit' :whistling: Lucky it worked out!
No squeeking, or dust (yet). I put some new pads in my standard brakes a few months back and they constantly made noise. Drove me nuts.
So today I drove into the city and am blown away by the power and feel of them. So i am pretty stoked with the upgrade.
do you there there is more pedal travel due to the small master cylinder?
it might require an upgrade
It makes no difference to the master cylinder - I reckon they feel a lot stiffer under foot, I know my brembos felt so much firmer under foot than the stockies, same with Chris'.
  • 3 weeks later...
Hey Chris,
completely OT, but how do you find the FK452's on the Stagea ?
I had a set on my last RWD and they were fantastic, have been thinking about getting a set for the Stag.
Looking at the I.D. of your wheels Chris, I'm sure they would fit behind the 350GT 18's I bought from you. Maybe measure when you do the 1000km bolt check and I'll measure the 18's?
The only thing I'd have doubts about is the caliper to wheel claerance, the calipers look very wide!
BTW nice pics in the current AMB mag, best job ever?:worship:
Hello, I checked with a supplier of these brakes on the G35driver.com forums. The 18" V35 coupe wheels require a spacer, while the 18" 350Z wheels are a-ok. Unfortunately for me I just bought some 18" coupe wheels, so for my V35 Sedan I might have to look at the Brembo's since my wife drives the car 90% of the time. Anything has got to be better than the single caliper job they used on these things!
Chris is your stagea a 4wd model ? as im looking every where for a brake upgrade kit for my m35 250trs four
trying to fing a 4wd kit
Any 350z or G35 brake kit will fit.
Only difference might be the fluid lines
i have been reading on the brembo and willwood sites and they all say that the 350 z upgrade kits cannot be used on AWD vehicles only rear whell drive
the 250t rs four stageas are AWD ??
seeing as it has 'FOUR' in the name, im gonna say yes lol
all turbo models in australia are AWD. the newer 3.5L models can come in RWD, however they are still automatic
so im being told from u guys that any 350z brake kit will work ???
yet they are telling me you cant use the brake kits on a AWD car ???
your telling me all turbo stags are AWD which i know
AWD and 4WD are different they use different diffs , just to let u know
Maybe PM, bbenny (he has Z33 Brembo's on his NM35) or spoolin12 (as you can see at the start of this thread, he has the 370z Akebono's on his which are much, much larger than the 350z Brembo's).
I believe that [[Danny]] also put 350z Brembo's on his M35 (ARX)
Remember, the 350z (RWD, man or auto) and the V35 (RWD or AWD, man or auto) have the same brake kit from factory as our M35's (RWD or AWD).
Of course I am referring to the non-Brembo cars, but it is a direct replacement if you want to upgrade.
How does a different diff affect the brakes you put on?
Have you asked them WHY they say you can't do it?
If it is a US supplier, ask them if the brake kit will fit a G35x (AWD Infinity G35)
AWD and 4WD are the same model in an M35. the driveline is the same
the NA models (series 1) have 4 speed autos and different diff ratios to suite the 4 speed.
the ONLY difference in driveline is the models with HICAS have a different rear subframe, ARX and AXIS has a slightly wider wheelbase, probably in the knuckle as the arms appear to be the same length
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
