Wait... Something is wrong then, I think mine will even open gate on high boost in 1st gear! That's 26psi :)
Will test with some videos tonight and see what I actually get.
probably starts to crack the gate but no way 26psi haha, I'd say 15 ish absolute max.
Shit I forgot to test!
Yeah might not hit that much, really depends on trye grip as well... If it wheel spins your not going to be as much boost, if you launch of limiter with drag slicks I'd imagine it would a lot of boost fast :)
Will try and remember again tonight haha
Yes but I was giving an example of how the turbo behaves respective of load. Not wether or not it will stay consistent if it reaches it's boost level. I felt it was a better example then saying you won't hit target boost in neutral (unless maybe your on limiter) as opposed to flat to the floor in third. The hill thing was just an easier comparison of load.
OP: read the manual to see if what I have said in my last post is in there and if it says the reason behind doing that mod. Might be for boost creep rather then your problem I forget. Otherwise I'd try putting stock parts bak on to trial (BOV and boost solenoid mainly) if it starts working then it will show you your problem
Yup sorry, I agree with what your saying just didnt want people to expect different boost levels in different gears with a well setup actuator/boost control system. You are 100% correct its easier to build boost with more load.
Got 1.38bar on the first attempt and 1.43bar on the second... Will upload the video when I have time :)
Don't know how people are only getting 0.3bar in first with a GT30, something must have been wrong!
20psi, in first gear with a GT30 on a RB25?
ok. Now I have seen it all.
Post a video or I call 110% bullshit.
yeah good call......
the only that you be possible is if you had the hand brake on to load it up :rofl2:
I could make a max of 5psi in first, nothing more. WIth a GT30 and 0.63 rear.
OP needs to look at if the wastegate is holding shut. Or put tension on it.
tow a boat up a hill in 1st gear, probably could hit 20psi :whistling:
Hows the foot in mouth tasting?!?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
