Just to add to the cause, when i bought my 33 GTS my friend bought it up from Melbourne. When it arrived, it was sporting GTR badges on the guards where the GT badges were supposed to be and poorly fitted GTR Rear pods. Epic fail, and they were pulled of very quickly was actualy ashamed to drive the car til they came off :S
Good work
wow, i opened this thread expecting to see pics.
fail.
and because im quite the joker and my car was quite the joke (to my delight).
i didnt necessarily like the GTS badge and seeing as i had a 400R bar i got a genuine R33 GTR badge from nissan and had a custom NON made up.(i later on sprayed the IC brackets black and then it looked schmick :) )
so this was my NON-GTR(R.I.P.) :(
haha damn gtr badges. my so called "mates" decided to put a gtr badge/sticker thing on my car when i didn't know - i saw it the next time i took my car out of course, but still in that time if it was seen.....:down:
Edited by kaitoukid
fail.
That badge is FAIL
the fact that you had to quote my whole post including 4 large photos is fail.
i achieved exactly what i wanted to achieve with that badge:pure ridiculousness.
At least you admit the ridiculousness. +1 for that one.
  • 4 weeks later...
Going back to Holdens with Chevy badges...
Looks like they are even putting a bit of effort into it now. Now nobody will know its a holden...
Its like what someone else said earlier, the only person they are fooling is themselves. People that don't know don't care, and people that do know think you are a tossa...
how bout you bugger off aye?
this thread is in no way about anything that isnt about GTR badges being put on GTS skylines.
capiche?
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
