Found an R31 coilover group buy.
Fronts utilize s13 camber tops. I know bolt pcd is the same as dr30 but will there be any problems with camber adjust-ability? It's my only concern with this kit as have heard in the past that use of s13 camber tops require 'flipping'(or something along those lines) to get any negative camber effect.
Here are some pics of the kit. You weld the fronts straight onto the base of the strut after chopping the tube off.
Edited by D-limo
https://www.sau.com.au/forums/topic/350896-s13-camber-tops-in-dr30/
Im no too sure if having a welded coilover setup will pass engineers/compliance/rego in any state, maybe check that first?
But as I have been told, all you need to do is put the left side strut on the right side of the car, the calipers will be on the nose side of the car instead of the back.
Jarryd,
The bolt PCD is identical, but in REVERSE and there lies your problem. If you want more than 1~2 degrees negative camber, you going to have to do some serious machining to the base plate to allow the ball plate to move far enough. If you can put up with minimal negative camber the S13 tops wont matter jack schit.
But if your planning to run SLICKS on track days, you're going to need about 5 degrees negative, or more. Otherwise if your going to use street legal grooved tyres 2 degrees will be more than enough.
DR30 camber tops are just about non existent today, even in Japan and if you search through Yahoo you will find just about ALL camber tops listed in DR30 are in actual fact S13.
Cheers, D
The ONLY alternative would be to re drill the stru towers to suit the S13 parts.
I have had S13 tops here and have taken them apart, turned them upside down & inside out & left to right & every which way and the end result is the same as what you started with.
I don't know how legal re drilling the towers would be, but one thing is certain, it would HAVE TO BE extremely precise.
Cheers, D
ok... they will fit in and work perfect if you have coilover McPherson struts ie same as the r31 or r30 had from factory as the pitch is steeper,
if however it is a conversion to s13 chapman style struts then you wont get as much camber angle! i can get 3 deg on mine but that is cause mine have an elongated hole in the top of the clevis..
Chur
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
