Fully dissembled RB26 R33 and plenty of R34 parts from cats stock pile.
Head was recoed and hot tanked. ATM it is fully disassembled in boxes.
R33 block fresh 87mm bore suit first upsize (was using pistons with real tight clearances so im positive it will be spot on for CP or JE's with 87mm pistons.
2 x R34 cranks one with spin bearing the other is under 1500km old but has a crack (was going to get crank shaft re builders to fix as it comes up god as new and way cheaper than $1400 for a new crank)
R34 oil pump and water pumps
R34 rods and pistons i think there is 8 or so?
6 h-beam rods 5 are identical 1 is slightly different.
Full individual throttle body setup (only missing plenum as it was a greddy)
sumps can be suplied @ extra cost.
$1000 the lot cash only and pickup.
ASR rb sump full race version NEW $500
STD gtr sump and diff $200
RWD rb26 alloy sump $150
TOMEI rb26 sump baffle new $150
answer to the emails:
Block and head is R33 rest is R34, they are the sum of all the parts i've had left over from builds over the years. I actually have 3 cranks i just found another which is 10k old but has a worn thrust face on the pull side (so perfect for std push clutch setup once repaired) they said it would be good as new, all journals are perfect.
The crank with the crack was sent away by my machine shop and i had it quoted up about a year ago but never got around to okaying the work and bought a new one as the car was making big power (800odd hp) so i did not want to chance it. Price was 1/4 the cost of a new crank to have it fixed. The other crank has spun number 6 journal and has never been inspected.
There was two complete engines so 99% of parts are there to make one with plenty of spares.
i do have another short engine but its got full ARP kit trust forged pistons and eagle rods.
What sort of coin are you chasing for the built short motor that you mentioned?
sum of parts and work in it are around 6k
but ive just stripped it down and its unchecked clearance etc wise probably take 2k as is or 3k re-ringed and bearing's just to be sure. Engine done 1500kms.
Do u have a pic of the asr sump? also how many liters is it and has it go windage flaps?
Also has it got the extended oil pick up?
Is the standard GTR sump and diff combo r32 or r33?
Cheers
Edited by BIGBOSS
Cheers
ASR sump is their top of the range race/circuit sump 8 or 9 lts, extended pickup, windage, traps and doors etc
GTR std sump was from R33 but same as R32 (no pic).
Hi mate very interested in a gtr crank, but not the cracked 1, could you please sent me a price and your location for 1 if still available. Can txt me on 0488338751
Hey tried to shoot you a PM about the built short block
Couldn't send it, could you PM me whenever suits.
Matt
Hi trent, ive reciently spoken to Stevel, the person you sold the cranks to, and am wondering if you could please update me with the known damage to the crank with jurnal damage.
Would a re grind and balance fix this?
Thanks for you time Simon.
Can text me on 0488338751
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
