Hey Guys just bought a stock (aftermarket Pod and Cat back) R33 95 with 144000kms on it.
Its pretty clean but now when I idle it revs up and down and occasionally stalls. Other than Idle the car runs extremely smoothly and pulls fine.
My house mate disconnected and reconnnected this hose (in orange circle) and it ran fine for about 5 mins before falling back to the old problem, any ideas on what the problem is?
Thanks heaps for the help guys, really happy with the car except for this.
https://www.sau.com.au/forums/topic/351135-new-r33-hunting-idle/
does the idle change when u move the steering wheel? If so, try cleaning the AAC valve, there's a tutorial on these forums
Nah doesnt affect it when I move the steering wheel, also gave the aac valve a good clean with carby cleaner and it didn't fix it, perhaps the valve itself is stuffed?
  • 3 months later...
is the factory bov recirculating still if not that will be your problem because factory bov spring to weak and leaks pressure when run to atmo
The spring isnt all that weak.. it will handle 300rwkw.
It is designed to leak at idle, so it leaks regardless of whether its plumbed back or not.
Id say that it isnt though. And because its leaking that air its overfuelling.
That, or the car is saying FUUU to all that silicon spray. haha.
  • 2 months later...
regardless of weather it fixes prob or not change
the fuels filter also clean the hot wire inside ya afm
if its dirty it will make a huge difference
also check the butterfly in the intake as it can get
a carbon build up and not seat properly in the intake
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
