Hey Guys just bought a stock (aftermarket Pod and Cat back) R33 95 with 144000kms on it.
Its pretty clean but now when I idle it revs up and down and occasionally stalls. Other than Idle the car runs extremely smoothly and pulls fine.
My house mate disconnected and reconnnected this hose (in orange circle) and it ran fine for about 5 mins before falling back to the old problem, any ideas on what the problem is?
Thanks heaps for the help guys, really happy with the car except for this.
https://www.sau.com.au/forums/topic/351135-new-r33-hunting-idle/
does the idle change when u move the steering wheel? If so, try cleaning the AAC valve, there's a tutorial on these forums
Nah doesnt affect it when I move the steering wheel, also gave the aac valve a good clean with carby cleaner and it didn't fix it, perhaps the valve itself is stuffed?
  • 3 months later...
is the factory bov recirculating still if not that will be your problem because factory bov spring to weak and leaks pressure when run to atmo
The spring isnt all that weak.. it will handle 300rwkw.
It is designed to leak at idle, so it leaks regardless of whether its plumbed back or not.
Id say that it isnt though. And because its leaking that air its overfuelling.
That, or the car is saying FUUU to all that silicon spray. haha.
  • 2 months later...
regardless of weather it fixes prob or not change
the fuels filter also clean the hot wire inside ya afm
if its dirty it will make a huge difference
also check the butterfly in the intake as it can get
a carbon build up and not seat properly in the intake
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
    • You'd really have to pull it apart further to know, it least you can be confident that the one heading to the back is not connected any more. There was once a ground on the shifter seal mount too, your head unit issue could be that simple
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
