Hey Guys just bought a stock (aftermarket Pod and Cat back) R33 95 with 144000kms on it.
Its pretty clean but now when I idle it revs up and down and occasionally stalls. Other than Idle the car runs extremely smoothly and pulls fine.
My house mate disconnected and reconnnected this hose (in orange circle) and it ran fine for about 5 mins before falling back to the old problem, any ideas on what the problem is?
Thanks heaps for the help guys, really happy with the car except for this.
https://www.sau.com.au/forums/topic/351135-new-r33-hunting-idle/
does the idle change when u move the steering wheel? If so, try cleaning the AAC valve, there's a tutorial on these forums
Nah doesnt affect it when I move the steering wheel, also gave the aac valve a good clean with carby cleaner and it didn't fix it, perhaps the valve itself is stuffed?
  • 3 months later...
is the factory bov recirculating still if not that will be your problem because factory bov spring to weak and leaks pressure when run to atmo
The spring isnt all that weak.. it will handle 300rwkw.
It is designed to leak at idle, so it leaks regardless of whether its plumbed back or not.
Id say that it isnt though. And because its leaking that air its overfuelling.
That, or the car is saying FUUU to all that silicon spray. haha.
  • 2 months later...
regardless of weather it fixes prob or not change
the fuels filter also clean the hot wire inside ya afm
if its dirty it will make a huge difference
also check the butterfly in the intake as it can get
a carbon build up and not seat properly in the intake
    • I downloaded the apps (for windows) and Consult 1 doesn't have this function on it for the Consult 1 plug which I'm pretty sure all Skylines have. You would think someone would have a workaround after 30 years for all Skylines which have ABS.
    • Also, I don't know the actual ABS system on the skylines, but a sneaky thing could be a piece of electronic equipment that makes the ABS think you're moving, and then same piece can send a signal for a locked up tyre... Activate ABS without slamming brakes...
    • The team at OBD2 Australia are pretty good, shoot them an email and ask them. I've dealt with them before for work stuff. I'd be shocked if it didn't work, so long as Consult can activate the ABS. But you might need to use KLine for it which would be the stopper, as I don't think that piece does KLine comms.
    • Yeah and hence my ghetto way of slamming the brakes, get the ABS to cycle, rebleed seems to be a sensible workaround.
    • Hey! Happy to help. Nothing inherently wrong with the adapter, it's more so with Brett Collins himself. He gave me a lot of incorrect information when I was in contact with him and was extremely rude when I challenged him. He stated I could not use any aftermarket twin plate clutches except for his own, not to use the dush shield, bla bla bla and it was all BS.  Collins stated to cut roughly 14mm's off the housing, I took off 15mm to make room for the dust shield. I would confirm with whatever adapter manufacturer you're using.
