As I am still learning the ins and outs of my car I was wondering if you can actually alter anything or play with any of the options in the menu pictured? So far the only thing I can pic from hear that you can use is the error log screen. Thoughts?
https://www.sau.com.au/forums/topic/351354-use-of-menu-functions-on-the-v/
There isnt alot there that you can play with except the sensors. the version is what is down loaded on your dvd rom. Its either XAA11001 or XAA110011 depending on what english conversion you had done.
The Navigation is for the map disk
And display diagnosis can tell you if something is unpluged.
Lastly I wouldnt press the same 2 butons that you pressed to get into that menu.
It brings up a menu bar second from the bottom that is missing and you dont want to go into that one.
So what im saying is dont play to much.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
