  • Replies 128
OK, I'm uploading the first 26 of the hundred or so photos I took on the day.
They can be found at http://www.flickr.com/photos/hicass/sets/72157625945281264/
EDIT
I didn't know flickr had that functionality :O
Shanil you left before i got to say gday. i had a look at your new toy. it's really clean. good buy! it's very sexy! love the rims.
That cool brother, I'm sure I'll be at many SAU events this year so we'll cross paths for sure!
Thanks Shaneo. I'd bought the RE30s to suit the 33R, but have decided they also look ok on the 34R... we are deliberating over whether bronze LMGT4 will look better than the F1 RE30s?
The gold Advan RGs are good combo with Terry's blue VS2 too.
Loved your new acquisition mate, didn't know they had carbon bonnets :thumbsup: As I said to you on the day I think it wasa smart buy for you getting a near-new Evo over an older R.
Had a few fave R34s on the day, wanted to chat but didn't get the chance as I was at the back of the pack and as soon as we pulled up at the truck stop we were off again then got split up at the pub(s)
OKOKOK - One of the few white R34s I've seen that I think looks awesome (and white doesn't detract from this one at all) - Nismo bodykit and silver LMGTs
JUN26L
Jamie's MNP II was also very nice - limited ed. 1 of only 300 I think?
F1 RE30s take my pick!
Thanks for the kind words on the Evo, suffering from the modification bug - working hard to fall broke even harder!
  • 4 weeks later...
  • 1 month later...
    • The HG high flow is excellent, and costs about the $$ you're talking about. But it, and probably every other highflow, uses a diffeent core than the original turo, and the original Hitatchi core is quite long. So, I think it is inevitable that there is likely no such thing as a highflow that just "bolts on" with no other effort required. And the same is likely true for HG's outright replacement "bolt on" turbos (the ATR things). And the same is likely true for anything similar from elsewhere. I have no idea if the cheap Chinese/Taiwanese complete turbos from eBay/Temu/etc are as bolt on as they claim. I mean, they claim the bolt onto the NAs as well as the turbos, and we know that can't be "bolt on". But it wouldn't matter because I'm not buying a $169 4 psi turbo for anything other than a paddock basher.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
