from memory, first you have to remove the wheel and get to the bottom of the shoclers and remove the bolt and nut.then youll have to remove the rear seats and then the back rest, when thatts out, you remove the parcel shelf to reach the top nuts.
  • 1 year later...
Should of looked at topic first, just took out all the boot linings, thinking I was gonna look at the shocks top mount ... what a surprise :verymad: , now onto the rear seat dismantle :wacko: .
Rear seat is easy az!! Basically 4 bolts and its out :D
  • 1 month later...
is it a must to remove the shocks on the rears to install the springs?
Watching a few videos, some cars only require removing one bolt and nut (for the back wheels) and the spring can easily be taken out from there instead of removing the whole shock assembly.
I have king springs coming in soon and also want to install them myself, haven't been able to find a thread that actually takes you step by step through it for a r34 GTT though.
I haven't actually seen the standard setup but based on the coilovers design I doubt it man! You can still DIY, plenty of help on here to walk you through it, any reason you spent money on springs rather than height adjustable coilovers? The old shocks are gunna need replacing one day so why not do the lot for the $1000 etc??
There's good reasons for not using height adjustable coilovers. For one, unless you weld them so you can't adjust the ride height, they are defectable. For two, unless you spend a lot more money, you will seldom get as good a damper in them as you get with just a normal Bilstein strut, or Koni D's, or whatever (good equipment) takes your fancy. This means that they won't work as well from new, and will probably die earlier. Not all cheap coilovers are rebuildable, and some of these no-name brands will probably not even exist when you come to want to rebuild them anyway. So unless they are a complete rip-off of some other established brand, rebuild parts may not be available. If you doubt this, just take a look back at forum posts from 5 years ago on the subject of coilovers and see if you remember the brand names being discussed.
Oh, and to suwidji, yes, the whole suspension unit must be removed to put new springs on. That's not that hard. But depending on how much force is needed to compress the spring to the right length to make it captive, you do stand a very good chance of injuring yourself as you disassemble them, and may not be able to put it back together if you get that far without embedding from steel into your skull. You need spring compressors to do the job safely.
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
