putting better valve springs in my car this weekend, anyone done this befor and can give some good pointers, i have the gear to fill the cylender with air to hold the valve in place when springs are out, i have also been told about placing string in the cyclender when all the way down and then winding to top dead center so if air fails the string will be a safe gard for valve dropping into block, my main question is about getting cams back in exact location, can i leave cams attached to cam gears when removing them so i just have to line cams back up when re-installing them? :domokun:
https://www.sau.com.au/forums/topic/351643-installing-valve-springs/
Well no you cant because you have to remove the rear plastic cover to remove that you have to remove the cam gears. Ill add my tips aswell as I just did my springs and I used the compressed air method but eventually one of the valves dropped because the compressed air caused the crank to spin for a sec lost pressure and down went the valve. So if your going to use the compressed method make sure you have someone holding the crank or put the ratchet against the body so it cant rotate. Or you can just do the string method.
In regards to lining everything up what I recomend and alot of other people do when you have everthing at TDC rotate the crank a little bit backwards in order to move piston 1 and 6 from TDC so then theres no need to worry if the cams arent in exactly right or rotate during when you tighten them up. Then when youve reinstalled the cams just set the cams to the correct postion then rotate the crank forward back to tdc.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
