I kinda just jumped into this because I accidentally starved my HX35 7blade of oil :( . A word to the wise, don't us F'ing stock Nissan oil feed fittings! There are _THREE_ hidden ninja restrictors! So I landed a brand new billet 5557 T3 .82 a/r rear for a good price. It will be going in my s13 with 25DE/30 with a tubular manifold (unfortunately its a T4 divided manifold so i will have to make an adapter :( ). Damn shame I don't get to put the twin scroll to use!
Looking for a very responsive street setup and a relatively quick 1/4 mile dragger (hoping for 11s!).
I know the new generation of Precision turbos is relatively new, but what do you guys think; Will i accomplish my goals above? Should I have gone larger so I could utilize a T4 divided setup? Is the T3 .82 going to run out of puff?
Thanks guys!
https://www.sau.com.au/forums/topic/351669-precision-5557-in-an-rb30/
But how can such a big turbo have the response that I'm looking for? The guy says "The GT4088 could be up your street, good responce and I dont think it ran out of puff." Good response? A GT40!?!?
Edited by ST240
Thanks guys!
I have a 5557 on an rb25... It chokes the 25 and only makes 245rwkw at 20 psi... Sell it.
Did you read that link I posted?
"a 1.06a/r T4 twinscroll housing builds boost faster than a .82a/r open T3"
"From that result I'd be picking a 1.05a/r twin scroll T4 EFR8374 to be an absolute torque monster on an RB30!"
Read through the RB30 dyno results and pick a turbo from there.
Would be such a shame to not use the T4 twinscroll manifold!
If your after maximum response and dont care about wasting your twinscroll T4 manifold then go a 3076 0.82. Can make a super responsive 300rwkw, check out Al's setup first dyno on Page 4 of RB30 dyno results.
You can get a GT3076R in a 1.06a/r twinscroll - that'd be insane. EFR7670 would be crushing, GT3582R power with better than GT3076R spool
Forgot about the 3076 in 1.06 twinscroll T4! Dont know much about this EFR7670, will have a read.
Serious? The thing is rated at 525 crank hp. What rear do you have on it?
Wow I can't believe a T4 1.08 twin scroll spools faster than a T3 .82!!!
Isn't a 5557 somewhere between a GT3071 and a GT3076? I have the .82 rear. I saw Al's setup and thats what I'm pretty much hoping for.
Damn. Looks like I might be selling it :( .
Edited by ST240
Jeez Justin I just read your posts in the Precision Billet Turbo thread. Disappointing indeed.
I would be quite pissed if I ran the 5557 up to 20 psi on my 30 and didn't make 300 kW. I wonder how inefficient that compressor is at its "525 HP rated" capacity...
Maybe I should just be a guinea pig and run it ;) .
I have a .82 rear... drops off 21psi to 18psi from 6k-7.8k rpm and wont make any more than 250rwkw on 98... The response isn't particulary awsome for the power either..
Sell it!
Sell it!
Hmm...no wonder they never really put any test results of this combo up on here.
Sell it!
I coulda sworn I saw you say you had a .63 in that thread...
Well sports fans.
I'll post up the dyno sheet tomorow.... However-
I ended up making 245 odd rwkw on 98 at 20psi (that drops off to 18psi at 8000rpm) from my 5557 .63 exh housing. All the usual supporting mods, no major restrictions.
I was a little dissapointed. For the lag I would have expected 255/260ish rwkw at that boost level.
It seems high boost is needed for the numbers with these turbo's. I just didn't want to run anymore boost on a stock 100k rb25.
I'll be going to a td06...
J.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
